跳转到主内容
加入维修社区 - 创建账户
PSP 2000 Display Replacement
你所需要的
  1. PSP 2000 Display Replacement, Battery: 步骤 1 中的图像 1,3 PSP 2000 Display Replacement, Battery: 步骤 1 中的图像 2,3 PSP 2000 Display Replacement, Battery: 步骤 1 中的图像 3,3
    • Place PSP face down, so that the UMD Drive is facing upwards.
    • Locate the battery door and open.
    • Remove the battery from inside.
    询问修复机器人
    添加评论
  2. PSP 2000 Display Replacement, Front Casing: 步骤 2 中的图像 1,1
    • This step requires the removal of the warranty sticker. Removing the sticker will void the warranty. According to the FTC removing this will not void your warranty.
    • Locate the sticker in the battery compartment labeled: "En: Warranty Void if Seal Damaged."
    • Remove the sticker using the PSP Opening Tools.
    • Under the sticker is a 5mm Phillips screw needed in the next step.
    询问修复机器人
    添加评论
  3. PSP 2000 Display Replacement: 步骤 3 中的图像 1,2 PSP 2000 Display Replacement: 步骤 3 中的图像 2,2
    • Remove four 5 mm Phillips from the case.
    • If the screws stick in the case, you can use a magnetized screwdriver to draw them out.
    询问修复机器人
    添加评论
  4. PSP 2000 Display Replacement: 步骤 4 中的图像 1,2 PSP 2000 Display Replacement: 步骤 4 中的图像 2,2
    • Remove the following screws from around the bezel:
    • Two 4 mm Phillips
    • One 5 mm Phillips
    • The two shorter 4 mm screws are on the top of the PSP; the longer 5 mm screw is on the bottom.
    添加评论
  5. PSP 2000 Display Replacement: 步骤 5 中的图像 1,2 PSP 2000 Display Replacement: 步骤 5 中的图像 2,2
    • Gently pry the front bezel away from the casing using a PSP opening tool.
    • Start on the right hand side of the PSP bezel, and carefully work the tool around the side.
    • If you want to clean the control buttons or D-pad, you can easily pop them out once the faceplate is off and wipe them clean.
    询问修复机器人
    添加评论
  6. PSP 2000 Display Replacement, Display: 步骤 6 中的图像 1,3 PSP 2000 Display Replacement, Display: 步骤 6 中的图像 2,3 PSP 2000 Display Replacement, Display: 步骤 6 中的图像 3,3
    • Remove the home bar by gently prying on the left and right sides of it with the opening tools. Lift the bar out of the device.
    • A ribbon cable connects the home bar to the logic board. Be careful not to damage the cable when removing the bar.
    添加评论
  7. PSP 2000 Display Replacement: 步骤 7 中的图像 1,3 PSP 2000 Display Replacement: 步骤 7 中的图像 2,3 PSP 2000 Display Replacement: 步骤 7 中的图像 3,3
    • With the home bar out of the way, gently pry up the display using the opening tools.
    • There is another ribbon cable attached to the bottom of the LCD. Be careful not to damage either of the connectors when removing.
    • Lift the black tabs of the ribbon cable connectors using a opening tool. Pull the ribbons out towards the bottom of the PSP to disconnect.
    • Gently lift out the display.
    添加评论
结论
取消:我没有完成这个指南。
67等其他人完成本指南。
espinks
于10/18/09注册
3,869 声望
创作了5篇指南
团队
Cal Poly, Team 6-3, Maness Fall 2009 Cal Poly, Team 6-3, Maness Fall 2009 的会员
CPSU-MANESS-F09S6G3
5 名成员
创作了48篇指南
6指南评论
That does’t seem that hard. Is this tutorial working with the PSP2004?
Jack Galinski - 回复 分享
Yes it is, just did it :)
Billy - 回复 分享
Thanks for the great tut just fixed a trash find psp with a cracked lcd.
myhero667 - 回复 分享
Parfait tutoriel pour remplacer mon écran de PSP 2004. Un grand merci
Ramius59 - 回复 分享
I was wondering why after replacing the screen that the new one only shows a blank black screen. The backlight turns on and it plays the boot up sequence and you can play around on the Home Screen, but you just cant see what you’re doing on the screen. Everything seems connected right. Any suggestions??
Dylan Thomas - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 37
过去 7 天: 180
过去 30 天: 881
总计 84,867
