跳转到主内容
加入维修社区 - 创建账户
PSP 1000 Buttons Replacement
你所需要的
  1. PSP 1000 Buttons Replacement, Battery: 步骤 1 中的图像 1,1
    • Turn the PSP over so its back is facing you.
    询问修复机器人
    添加评论
  2. PSP 1000 Buttons Replacement: 步骤 2 中的图像 1,2 PSP 1000 Buttons Replacement: 步骤 2 中的图像 2,2
    • Locate the battery casing button on the rear-left side of the PSP.
    • Press down the button and remove the battery cover.
    添加评论
  3. PSP 1000 Buttons Replacement: 步骤 3 中的图像 1,2 PSP 1000 Buttons Replacement: 步骤 3 中的图像 2,2
    • Using your finger, remove the battery upwards from the system as shown.
    添加评论
  4. PSP 1000 Buttons Replacement, Front Casing: 步骤 4 中的图像 1,1
    • Remove the four screws shown with a Phillips #00 screwdriver.
    • You will have to peel back the warranty sticker to access the lower screws.
    添加评论
  5. PSP 1000 Buttons Replacement: 步骤 5 中的图像 1,2 PSP 1000 Buttons Replacement: 步骤 5 中的图像 2,2
    • Remove the screw from the bottom side of the PSP. Keep it separated from the rest of the screws.
    • Remove the two screws from the back righthand side within the holes.
    询问修复机器人
    添加评论
  6. PSP 1000 Buttons Replacement: 步骤 6 中的图像 1,2 PSP 1000 Buttons Replacement: 步骤 6 中的图像 2,2
    • Gently separate the outer plastic casing from the rest of the system as shown.
    询问修复机器人
    添加评论
  7. PSP 1000 Buttons Replacement, Buttons: 步骤 7 中的图像 1,3 PSP 1000 Buttons Replacement, Buttons: 步骤 7 中的图像 2,3 PSP 1000 Buttons Replacement, Buttons: 步骤 7 中的图像 3,3
    • If the Arrow Buttons are not functioning properly, flip over the outer casing and locate the inside of the buttons, as shown
    • Carefully remove the black rubber backing off of the buttons.
    • Clean the inside of the rubber and the outside of the buttons with a cloth.
    询问修复机器人
    添加评论
  8. PSP 1000 Buttons Replacement: 步骤 8 中的图像 1,2 PSP 1000 Buttons Replacement: 步骤 8 中的图像 2,2
    • If needed, replace the old buttons with a new set (which can be purchased from Sony or other electronics stores).
    • Carefully re-insert the buttons. This should not require excess force, as the buttons should fit if they are arranged correctly.
    • Gently re-apply the back rubber to the back of the buttons.
    询问修复机器人
    添加评论
  9. PSP 1000 Buttons Replacement: 步骤 9 中的图像 1,2 PSP 1000 Buttons Replacement: 步骤 9 中的图像 2,2
    • If function buttons (x, square, circle, triangle) need to be replaced, find the corresponding black rubber backing on the inside of the casing.
    • Carefully remove the back rubber to expose the rear side of the buttons as shown. (This can be done using your hands.)
    询问修复机器人
    添加评论
  10. PSP 1000 Buttons Replacement: 步骤 10 中的图像 1,2 PSP 1000 Buttons Replacement: 步骤 10 中的图像 2,2
    • Next, carefully clean the receiving end of the buttons on the motherboard (shown on picture) with a cloth.
    • If the buttons are clearly damaged, then they need to be replaced.
    • Add the new ones in the form, with the correct button order. (The correct button order has the Triangle on the top, Square on the right, Circle on the left, and X on the bottom).
    • Be very careful! The buttons only go in one way. If you have trouble fitting them in, rotate them in their given spots until they fit in easily. Do NOT force them. Forcing the buttons in may cause damage.
    询问修复机器人
    添加评论
  11. PSP 1000 Buttons Replacement: 步骤 11 中的图像 1,1
    • Once buttons are correctly replaced, the back rubbers are fit back onto the buttons, refer back to Replacing the Housing to reattach the casing.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
36等其他人完成本指南。
Henry Lee
于01/14/10注册
908 声望
创作了4篇指南
团队
Cal Poly, Team 5-6, Forte Winter 2010 Cal Poly, Team 5-6, Forte Winter 2010 的会员
CPSU-FORTE-W10S5G6
5 名成员
创作了34篇指南
13指南评论
It's a helpful guide,thx
青木一誠 - 回复 分享
Great guide. I highly Recomend this to anyone that needs to replace their PSP buttons
unashamed45 - 回复 分享
Otimo guia recomendo.
richardmosman - 回复 分享
use magnetised screwdriver i had a normal one and it was a pain in the ass to put those tiny little bastards back
Nagy Dániel - 回复 分享
Thank you this was a great guide
BLAISE of BASH - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 25
过去 7 天: 213
过去 30 天: 979
总计 103,821
