简介
使用本指南以移除或替换您PS4 Slim上的硬盘。
你所需要的
沿顺时针方向,用T8安全螺丝刀,拧下藏在保修标签后长为5毫米的螺丝。
T8 fits like a glove for me
Is there anything else you can use
randomweeb - 回复
A small flathead screwdriver will work
There is a small metal rod in the middle of the screw that isn’t allowing my t8 inside. Any insight on this?
Some T8 bits have a hole in the middle that will allow that rod to go through; some do not. If you have a set of multiple bits, check if there are any others labeled T8 or TR8 with that hole in the middle.
Nicholas -
There is a metal thing inside of the screw slot any insite on this?
将您的PS4 Slim倒置,使刚刚拧下来的螺丝的那一面面向您。
用手指从两个面向您的边角撬开底盖。
向后滑动并且抬起底盖就可以移除它了。
It says to place it upside down, but didn't you do so in the previous step? I've been trying to unscrew the screw with my screwdriver that I got from here and if I had to had the system right side up, I'm afraid I might've stripped the screw from all the force I tried to use to get the screw out that will NOT budge. It didn't even move the slightest after removing the warranty sticker.
There is a single clip on the left side about 5cms in, and another clip on the right side equidistant to the one on the other side. Jamming a spudger in there first, and lifting those clips helped, and then I had to slide down to lift a total of 4 clips on each side (each about 4cms apart). Then push the cover away from you, if that makes more sense than “sliding it towards the back corners”, since the back corners are technically facing you.
I saw many video and tried it my self, you have to remove the hard disc before removing any cover.
用T8螺丝刀逆时针拧下两颗螺丝(左侧螺丝长31.0mm,右侧螺丝长24.0mm)。
用#1十字螺丝刀逆时针拧下一颗3.0mm长的螺丝。
UK model seems to be different here. There's no Philips screw where there is on your image.
This regards EU models in general, i think. My danish version is the same.
CUH-2215B doesn't seem to have the top antenna screw
移除四颗固定电源的16mm长的十字螺丝。
Only 2 Phillips actress here on my UK
Only 2 phillips screws on the US one as well.
I also only have two screws here in the US.
CUH-2215B has two T9 Security Torx screws on metal shield and two Phillips screws
向上移除覆盖在电源顶部的金属片。
I think the metal sheet protects the rest of the console or something from heating too much.
顺着固定天线的金属板底部的凸出部分拆下天线。
What does this mean for part do? This part is not present in my console nor is the space where it's supposed to reside as shown in the picture above.
Me neither, guess they are different models.
The model shown in this tutorial is the PS4 Slim CUH-2115, because it has the WiFi Bluetooth antenna attached to the PSU.
将PlayStation 4 Slim背面朝上。
用#1十字螺丝刀逆时针拧下一颗4mm长的螺丝。
it's usually pretty straightforward to remove the HDD first on any Playstation System
How do you get it when the screw is stripped
用手或镊子将电源上的排线小心地断开。
将电源完全取下。
Your guide is good but detail. Could be alot better for a start you forgot to mention the screw on the other side that must also be removed to let the power supply out of ps4 slim
Could you replace a ps4 slim model CUH-211B with a N16-160P1A power supply
Just because I feel like this needs to be stated clearly, “Do no attempt to pull the plug out by the wires!”
Pull from the plastic, male end of the plug or you’re going to end up have a very bad day.
Literally no way I can do it by the plastic, the only way is wires. Gotta risk it I guess
Misha FV -
You are right, pulling the wires is entirely wrong. I used the small rectangular, thin blue plastic to push the cable back from the socket. It was too tight. From my experience of repairing, never pull wires. The consequences of damaging it are not worth it.
This cable is very hard to remove from the connector. It's much easier to unplug this cable from the motherboard side (in step 20) because you can push the connector out from behind. (This might only be true for some motherboard revisions.)
You can leave the power supply propped up on top of the console, like shown in the first picture. After you've unplugged the two cables in step 13, you can put the power supply back where it was to make flipping the console over easier.
This is about where I'd give up
使用T8螺丝刀沿逆时针方向拧下图中的31毫米的大螺丝。
使用1号十字螺丝刀沿逆时针方向拧下如图的十个5毫米螺丝。
I have a ps4 model CUH-2215B and all the orange screws were replaced with molded plastic pins. They don’t come out. I could rip the heads off with pliers or something, but idk how it would go back together.
I have the same model as you and was stopped by this discovery, what i would try to do is remove them with pliers anyway and just use some spare small screws in the holes and see if that works, but I think no harm would happen if you just leave them out since it’s just a plate being held on and no important components are being held in place exclusively by the black pins.
Many of the screws were replaced with plastic rivets. Just use a straight head jewelers screw driver or very small chisel to shear off the head of the rivet by hitting the screw driver or chisel with a hammer. Be sure to keep the screw driver or chisel on a steep angle so not to place force down into to console. No need to replace them when re-assembling, They are not needed.
Anyway of ur gonna clean ur ps4 , it's better to remove the bottom one , u can get the motherboard without even touching that cover , it's not so necessary
捏住硬盘的有两个黑色塑料爪的一边,抬起以移除硬盘。
Where is the part number so I can order the exact fit? I have a older ps4 not the pro
Neto Rosas - 回复
Die Anleitung ist unvollständig und hört auf wenn es erst richtig los geht. Das Laufwerk ist noch drin und die Konsole muss restlos entkernt werden. Wärmeleitpaste sollte zur Hand sein. Bitte bitte ergänzt das noch. Es suggeriert das es deutlich einfacher ist, als es ist.
شكراً!!!!!!!!!!
SO basically I just wasted my time reading this whole guide only to find out it's not to replace the whole drive?
Nice.
Ich musste letzt endlich die komplette PS4 zerlegen, um das komplette Laufwerk zu wechseln. Bitte hier nachbessern.
This yet another not fully completed guide. This is NOT a full disc drive replacement.
若要复原您的设备,按以上顺序反向操作即可。
99等其他人完成本指南。
由衷感谢以下译者:
55%
Evyde HF正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
24条评论
incomplete guide, what replacement? the last step is taking the cover off but what about the disk drive?
Yeah, where's the ending to this?
To remove the complete drive you have to remove the motherboard. with the motherboard removed some of the above steps may not be necessary.
This guide is useful if you just need to remove disc or clean laser.
when replacing do you have to swap a board like the PS4’s of the past?
Nope, on the ps4 slim the optical drive is not married to the motherboard so any drive as long is the same model will work with any motherboard
What drive is used for replacement? Anyone have a link?
Newer ps4 slim has some black buttons on the drives instead of the 10 screws I’m stuck on getting the plate to the disc drive any suggestions????
I had to shave off the tops of those black buttons with a pocket knife to get the plate to come off.
The screw behind the warranty is not a T8 , it’s a TR8 (Tamper Resistant) screw. Just so you know which screwdriver to ACTUALLY buy/use.
T8 works fine
hi guys, is it possible to replace a ps4 slim disc drive with a standard ps4 disc Drive?
thank you
Nope i’m afraid you’ll have to buy the same model of ps4 slim disc drive with same one.
Hi.
I have the ps4 slim, the optical drive stopped working. I been through the process here and replaced the drive with a new one but the new one won't work either. Any suggestions?
this will help me get my PS4 repaired
i just need to get a new disc drive online
Thanks for putting this up. I was wondering how different it was going to be, compared to tearing down the Pro.
This guide is incomplete.If you want to actually replace the disc drive,then refer to the fan guide. The entire system let's be taken apart to get to the disk drive and or the fan. I also Ordered a replacement drive and installed it properly and it does not work
I replaced the optical drive but it only accepts the disc part of the way in. It's like something is blocking it because I can hear and fell the pull of the feed on the disc. I've taken it apart several times to check. What am I missing?
I'm having the same problem
So I replaced it but it want take any discs at all? Im not sure what to do
THIS
Not even a full guide💀💀
Remove the screw directly to the left of that one in the picture as well. Should be silver.
Elizabeth Johnson - 回复
ihr seid so ein scheiß haufen das stimmt über haubt nix
Toaster 95 - 回复
einfach alles stimmt nicht
Toaster 95 - 回复
Quitar la pegatina anula la garantía en España al menos
Ana y Francisco - 回复
So becore you start on this guide if you read the comments at the last step, this guide is geared more towards repairing of the disc drive not replacing the entire optical disc drive, i have done mine already and the guide does help get you halfway there but you are gunna need a bit more to pull the entire disc drive out, i will post another comment on the last step so you can follow these steps and then mine to further reference from that point on. See ya on the last step of the guide 🤘
Walter Gamboa - 回复
