跳转到主内容
加入维修社区 - 创建账户
PDP Rematch Cable Replacement
你所需要的
  1. PDP Rematch Cable Replacement, Faceplate: 步骤 1 中的图像 1,2 PDP Rematch Cable Replacement, Faceplate: 步骤 1 中的图像 2,2
    • Grip one side of the controller firmly.
    • Insert an opening pick into the crease between the faceplate and the body of the controller.
    • Once the pick creates a gap in the crease, gently insert another pick into a different section of the crease.
    • Carefully move the picks along the controller's crease line until you hear a popping sound.
    • Gently lift off the faceplate by hand.
    询问修复机器人
    添加评论
  2. PDP Rematch Cable Replacement: 步骤 2 中的图像 1,2 PDP Rematch Cable Replacement: 步骤 2 中的图像 2,2
    • Remove the 8 mm screws from the hard cover using a JIS #00 screwdriver.
    • Since the screws have been removed, avoid shaking or moving your controller too much to prevent other buttons from falling out.
    询问修复机器人
    添加评论
  3. PDP Rematch Cable Replacement: 步骤 3 中的图像 1,2 PDP Rematch Cable Replacement: 步骤 3 中的图像 2,2
    • Gently lift off the hard cover with your hand; it should not need much force.
    询问修复机器人
    添加评论
  4. PDP Rematch Cable Replacement, Cable: 步骤 4 中的图像 1,1
    • Remove the two screws on the motherboard with a JIS #000 screwdriver.
    • Gently flip the motherboard up to see the other side.
    询问修复机器人
    添加评论
  5. PDP Rematch Cable Replacement: 步骤 5 中的图像 1,1
    • Remove the cable from its plug on the motherboard.
    • This should give you room to carefully detach the Male Pitch Terminal Pin Header from the Female Terminal Pin.
    询问修复机器人
    添加评论
  6. PDP Rematch Cable Replacement: 步骤 6 中的图像 1,1
    • Take the new cable and thread it through the slot. The terminal block should fit loosely into the slot.
    • Then, insert the Male Pitch Terminal Pin into the Female Terminal Pin.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
Sydney Foster
于01/30/24注册
97 声望
撰写一个指南
1指南评论
Where do I buy the replacement cord from?
Keithy Bruce - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 50
总计 678
