跳转到主内容
加入维修社区 - 创建账户
PDP Afterglow Fener Wireless Dongle USB Wire Repair
你所需要的
    1. PDP Afterglow Fener Wireless  Dongle USB Wire Repair, PDP Afterglow Fener Wireless  Dongle USB Wire Repair: 步骤 1 中的图像 1,3 PDP Afterglow Fener Wireless  Dongle USB Wire Repair, PDP Afterglow Fener Wireless  Dongle USB Wire Repair: 步骤 1 中的图像 2,3 PDP Afterglow Fener Wireless  Dongle USB Wire Repair, PDP Afterglow Fener Wireless  Dongle USB Wire Repair: 步骤 1 中的图像 3,3
      • First, remove the heat shrink from the new USB.
      • Then remove the signal shield protection from the new USB.
      • Next, cut the 4 wire ends that are now protruding from the end of the USB.
      询问修复机器人
      添加评论
    2. PDP Afterglow Fener Wireless  Dongle USB Wire Repair: 步骤 2 中的图像 1,3 PDP Afterglow Fener Wireless  Dongle USB Wire Repair: 步骤 2 中的图像 2,3 PDP Afterglow Fener Wireless  Dongle USB Wire Repair: 步骤 2 中的图像 3,3
      • Then do the same process as above, for the USB wire coming out of the dongle itself.
      • Bend the wire ends so that they form hook shapes.
      • Connect the two hooks together.
      询问修复机器人
      添加评论
    3. PDP Afterglow Fener Wireless  Dongle USB Wire Repair: 步骤 3 中的图像 1,3 PDP Afterglow Fener Wireless  Dongle USB Wire Repair: 步骤 3 中的图像 2,3 PDP Afterglow Fener Wireless  Dongle USB Wire Repair: 步骤 3 中的图像 3,3
      • Once hooked, twist the two wires together to keep a strong connection.
      • Use a helping hand or other platform to perform the soldering.
      • Now solder the two wires together. Be careful to avoid melting the heat shrink otherwise it may get onto the copper wires.
      询问修复机器人
      添加评论
    4. PDP Afterglow Fener Wireless  Dongle USB Wire Repair: 步骤 4 中的图像 1,2 PDP Afterglow Fener Wireless  Dongle USB Wire Repair: 步骤 4 中的图像 2,2
      • Next you can use a heat gun to melt the heat shrinks together for maximum wire protection.
      询问修复机器人
      添加评论
    5. PDP Afterglow Fener Wireless  Dongle USB Wire Repair: 步骤 5 中的图像 1,2 PDP Afterglow Fener Wireless  Dongle USB Wire Repair: 步骤 5 中的图像 2,2
      • Finally, you can cover the whole thing with either a large heat shrink, or some electrical tape.
      询问修复机器人
      添加评论
结论
This guide does not require reassembly, as the guide itself is re-attaching the USB.
取消:我没有完成这个指南。
团队
UMass Dartmouth, Team 5-3, Gulbrandsen Fall 2015 UMass Dartmouth, Team 5-3, Gulbrandsen Fall 2015 的会员
UMASSD-GULBRANDSEN-F15S5G3
3 名成员
创作了20篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 33
总计 2,099
