跳转到主内容
加入维修社区 - 创建账户
Oregon Scientific RM318PA Power Switch Replacement
你所需要的
    1. Oregon Scientific RM318PA Power Switch Replacement, Battery Compartment Cover: 步骤 1 中的图像 1,3 Oregon Scientific RM318PA Power Switch Replacement, Battery Compartment Cover: 步骤 1 中的图像 2,3 Oregon Scientific RM318PA Power Switch Replacement, Battery Compartment Cover: 步骤 1 中的图像 3,3
      • Hold clock so that the clock face is facing away from you.
      • Using your thumbs, push up on the battery cover.
      • Once battery cover is removed, pull down on AC Adapter Jack.
      询问修复机器人
      添加评论
    2. Oregon Scientific RM318PA Power Switch Replacement, Batteries: 步骤 2 中的图像 1,1
      • Use one hand to stabilize the clock.
      • Using your other hand, push batteries toward spring and pull out at an angle.
      询问修复机器人
      添加评论
    3. Oregon Scientific RM318PA Power Switch Replacement, Back of Projection Clock: 步骤 3 中的图像 1,3 Oregon Scientific RM318PA Power Switch Replacement, Back of Projection Clock: 步骤 3 中的图像 2,3 Oregon Scientific RM318PA Power Switch Replacement, Back of Projection Clock: 步骤 3 中的图像 3,3
      • Use a Plastic Opening Tool to pry off the silver casing on the back.
      • Pry at the top of device.
      • Once the back is open at the top, pry at the side of the device closest to the battery compartment.
      • On/Off switch should come off with casing.
      询问修复机器人
      添加评论
    4. Oregon Scientific RM318PA Power Switch Replacement, On/Off Switch: 步骤 4 中的图像 1,2 Oregon Scientific RM318PA Power Switch Replacement, On/Off Switch: 步骤 4 中的图像 2,2
      • Insert switch into slot as shown in picture. Push in until you hear a "click."
      • Replace the back of the clock by pressing cover back into place.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
3等其他人完成本指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 33
总计 1,878
