跳转到主内容
加入维修社区 - 创建账户
Optoma HD20 Fan Replacement
你所需要的
  1. Optoma HD20 Fan Replacement, Disassembling Optoma HD20 Cover: 步骤 1 中的图像 1,2 Optoma HD20 Fan Replacement, Disassembling Optoma HD20 Cover: 步骤 1 中的图像 2,2
    • Twist the focal cap clockwise until it is fully extended.
    • Remove the focal cap by pulling it straight out.
    添加评论
  2. Optoma HD20 Fan Replacement: 步骤 2 中的图像 1,1
    • Use a Phillips #1 screwdriver to remove the three 7.5mm screws on the bottom of the device.
    询问修复机器人
    添加评论
  3. Optoma HD20 Fan Replacement: 步骤 3 中的图像 1,1
    • Use a plastic opening tool to gently pry the top cover off of the device.
    • It is easier to pry off the cover from the back side just above the HDMI ports.
    询问修复机器人
    添加评论
  4. Optoma HD20 Fan Replacement: 步骤 4 中的图像 1,1
    • When removing the cover, be cautious of the ribbon connecting the top buttons to the main circuit board. The ribbon must be disconnected before proceeding.
    • Remove the ribbon by disconnecting it from the main circuit board.
    • Lift up the clip holding it down and pull the ribbon out.
    添加评论
  5. Optoma HD20 Fan Replacement, Fan: 步骤 5 中的图像 1,1
    • Peel off the tape that is holding the metal casing down.
    询问修复机器人
    添加评论
  6. Optoma HD20 Fan Replacement: 步骤 6 中的图像 1,2 Optoma HD20 Fan Replacement: 步骤 6 中的图像 2,2
    • Use a Phillips #1 screwdriver to unscrew the nine 4.5mm screws.
    • Use a Phillips #0 screwdriver to unscrew the three 2.5 mm screws. This will allow you to remove the metal casing.
    添加评论
  7. Optoma HD20 Fan Replacement: 步骤 7 中的图像 1,1
    • Remove the metal casing by lifting it up off of the circuit board.
    询问修复机器人
    添加评论
  8. Optoma HD20 Fan Replacement: 步骤 8 中的图像 1,1
    • Unplug the six wires stemming from the circuit board.
    询问修复机器人
    添加评论
  9. Optoma HD20 Fan Replacement: 步骤 9 中的图像 1,1
    • Use a Philips #1 screwdriver to remove the four 4.5 mm screws
    添加评论
  10. Optoma HD20 Fan Replacement: 步骤 10 中的图像 1,1
    • Remove the three 4.5 mm screws using the Philips #1 screwdriver.
    添加评论
  11. Optoma HD20 Fan Replacement: 步骤 11 中的图像 1,1
    • Remove the two 4.5 mm screws located on either side of the VGA/SCART port using a 5 mm nut driver. This will further release the plastic backing from the motherboard.
    询问修复机器人
    添加评论
  12. Optoma HD20 Fan Replacement: 步骤 12 中的图像 1,1
    • Slightly rotate the motherboard clockwise. This will prevent ports from getting caught on the plastic backing.
    • Lift the plastic backing to remove it.
    添加评论
  13. Optoma HD20 Fan Replacement: 步骤 13 中的图像 1,1
    • Ensure all screws are removed
    • Lift up the motherboard and take out the metal container beneath it.
    • Do this very carefully as there is still one cable attached.
    询问修复机器人
    添加评论
  14. Optoma HD20 Fan Replacement: 步骤 14 中的图像 1,1
    • Unplug the white connector underneath the right side of the circuit board.
    • To remove, pinch both sides of the connector and pull it away from the circuit board.
    询问修复机器人
    添加评论
  15. Optoma HD20 Fan Replacement: 步骤 15 中的图像 1,2 Optoma HD20 Fan Replacement: 步骤 15 中的图像 2,2
    • Use a Phillips #1 screwdriver to remove four 5 mm screws. This will release the fan.
    添加评论
  16. Optoma HD20 Fan Replacement: 步骤 16 中的图像 1,2 Optoma HD20 Fan Replacement: 步骤 16 中的图像 2,2
    • Pull the fan away from the metal housing unit.
    • Gently lift the fan up and out of the device. The fan is now removed.
    添加评论
结论
取消:我没有完成这个指南。
6等其他人完成本指南。
Trever
于01/22/15注册
1,282 声望
创作了6篇指南
团队
Cal Poly, Team 21-23, Maness Winter 2015 Cal Poly, Team 21-23, Maness Winter 2015 的会员
CPSU-MANESS-W15S21G23
4 名成员
创作了6篇指南
6指南评论
Very nice set of instructions! Excellent images and identification of items to remove. Thank you!
Graveyard Workshop - 回复 分享
Do you know where to get this fan for replacement? Having trouble finding a parts list.
Sterling Grogg - 回复 分享
Small fan is GB1245PKVX-8, large fan is KDE1285PTV1
Gyrovague - 回复 分享
I am trying to determine if the fan works or not. Should the fan come on when there is no bulb in the projector? I removed the bulb when it burned up and I am not sure whether it was due to a failed fan or simply the bulb.
merrill277 - 回复 分享
Amazing! Thank you!!! Took a bit of effort to get the fan but in the end it worked like a charm!! Thank you for saving money!!!!
Mike Popov - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 29
过去 30 天: 99
总计 14,396
