跳转到主内容
加入维修社区 - 创建账户
Optoma HD20 Air Filter Replacement
你所需要的
  1. Optoma HD20 Air Filter Replacement, Disassembling Optoma HD20 Cover: 步骤 1 中的图像 1,2 Optoma HD20 Air Filter Replacement, Disassembling Optoma HD20 Cover: 步骤 1 中的图像 2,2
    • Twist the focal cap clockwise until it is fully extended.
    • Remove the focal cap by pulling it straight out.
    添加评论
  2. Optoma HD20 Air Filter Replacement: 步骤 2 中的图像 1,1
    • Use a Phillips #1 screwdriver to remove the three 7.5mm screws on the bottom of the device.
    询问修复机器人
    添加评论
  3. Optoma HD20 Air Filter Replacement: 步骤 3 中的图像 1,1
    • Use a plastic opening tool to gently pry the top cover off of the device.
    • It is easier to pry off the cover from the back side just above the HDMI ports.
    询问修复机器人
    添加评论
  4. Optoma HD20 Air Filter Replacement: 步骤 4 中的图像 1,1
    • When removing the cover, be cautious of the ribbon connecting the top buttons to the main circuit board. The ribbon must be disconnected before proceeding.
    • Remove the ribbon by disconnecting it from the main circuit board.
    • Lift up the clip holding it down and pull the ribbon out.
    添加评论
  5. Optoma HD20 Air Filter Replacement, Air Filter: 步骤 5 中的图像 1,3 Optoma HD20 Air Filter Replacement, Air Filter: 步骤 5 中的图像 2,3 Optoma HD20 Air Filter Replacement, Air Filter: 步骤 5 中的图像 3,3
    • Carefully peel off each air filter from the device
    • Pull up on the air filter to remove it.
    添加评论
  6. Optoma HD20 Air Filter Replacement: 步骤 6 中的图像 1,1
    • Remove the air filter from the device.
    • Try not to deposit dirt from the air filter into the inside of the device.
    添加评论
结论
取消:我没有完成这个指南。
2等其他人完成本指南。
Trever
于01/22/15注册
1,282 声望
创作了6篇指南
团队
Cal Poly, Team 21-23, Maness Winter 2015 Cal Poly, Team 21-23, Maness Winter 2015 的会员
CPSU-MANESS-W15S21G23
4 名成员
创作了6篇指南
1指南评论
There were no filters where the photos indicate.
Michael - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 15
过去 30 天: 69
总计 13,567
