简介
This guide will walk you through how to remove the phone's screen, which includes the LCD panel and digitizer.
你所需要的
Power off the phone by pressing the button on the right side of the phone, it will be the smaller button.
Press and hold the button down for a few seconds, until the option "Power Off" appears on the screen.
Select "Power Off" on the screen to turn off the phone.
Using a heat gun, apply slow and even heat to the edges of the back panel.
While heating the back panel, use a Jimmy to test if the adhesive is soft enough to allow the panel to separate from the device.
Carefully detach the back panel, using opening picks to hold the panel apart from the device.
Once most of the edges are separated from the device, attach a suction cup to the back panel.
Using a PH000 screwdriver, remove the following seven screws circled with red and orange:
Four (longer) PH000 screws
Three shorter PH000 screws
Once all of the screws are removed, proceed to using a plastic spudger to pry the metal cover off.
There are two clips near the bottom, right above the battery, so start by prying on the bottom edge of the plate.
Once all of the components on the back of the phone have been removed (battery, SIM card, etc), prepare for a battle with your heat gun and "oven mitts".
Using your heat resistant glove to hold onto the phone, evenly heat the edges of the phone.
Spend about 15-20 seconds on a small section about 2 inches long to make sure that it is sufficiently hot to remove the adhesive
After sufficiently heating a section of the edge, use the jimmy tool and slide it between the glass screen and the aluminum bezel of the phone.
Proceed to gently slide the jimmy around the area that has been heated to remove the the screen from the adhesive.
Having heat resistant gloves are very important as the device will get very hot and will burn your fingers if you come into contact directly with the phone.
After removing the adhesive and the screen is now loose from the phone, you'll notice that it is still attached to the back through a connector.
On the back of the phone, unclip the connector to the screen located on the bottom right hand side of the phone using a plastic pry tool.
Now that the pin is disconnected, you will have to gently slip the connector through the hole in the back of the phone to free the entire screen.
Once the connector is slipped through the hole, the screen should be free from the phone for good.
43等其他人完成本指南。
19指南评论
Does anyone know where to get a screen for the opx?
Dan Redmond - 回复 分享
i just ordered one from aliexpress.
anyone knows the best way to glue the screen back onto the x? 3M 2 sided tape 2mm thickness is ok?
thanks
Hi Kill,
Did u order the display and touch or just the display? and which web site did u order it from?
Aditi Mangal
ADITI MANGAL - 回复 分享
I'm also interested! can you post a link of the site?!
andreaartico - 回复 分享
My one plus x got fell from my hand. Now the display slowly getting fading away with blurriness. It's almost completely over the phone now :(
whats the options available now? and what will be the cost of display set for the replacement?
