跳转到主内容
OnePlus 3 Back Cover Replacement
你所需要的
  1. OnePlus 3 Back Cover Replacement, SIM Card Tray: 步骤 1 中的图像 1,3 OnePlus 3 Back Cover Replacement, SIM Card Tray: 步骤 1 中的图像 2,3 OnePlus 3 Back Cover Replacement, SIM Card Tray: 步骤 1 中的图像 3,3
    • Insert a SIM eject tool, bit, or straightened paperclip into the hole located between the SIM card slot and the power button.
    • Press firmly to eject the SIM card tray.
    • During reinstallation, make sure that the SIM card tray is properly oriented. It fits in only one direction.
  2. OnePlus 3 Back Cover Replacement, Back Cover: 步骤 2 中的图像 1,1
    • Remove the two 2.6 mm T2 screws from the bottom edge of the phone.
  3. OnePlus 3 Back Cover Replacement: 步骤 3 中的图像 1,3 OnePlus 3 Back Cover Replacement: 步骤 3 中的图像 2,3 OnePlus 3 Back Cover Replacement: 步骤 3 中的图像 3,3
    • There is a high risk of damaging the display panel if this opening procedure is improperly followed.
    • The following three steps show how to pry the rear case from the plastic frame. Read through the steps first before attempting the procedure.
    • There are two different seams between the screen and the body of the phone:
    • Display panel seam: This seam is part of the display assembly. Do not pry at this seam, or you will separate and damage the display panel.
    • Frame seam: This is where the plastic frame meets the back cover. It is recessed into the back cover. Only pry at this seam.
    • There are fourteen clips that hold the frame against the rear case. Be aware of their location as you pry the back cover off in the following steps.
  4. OnePlus 3 Back Cover Replacement: 步骤 4 中的图像 1,3 OnePlus 3 Back Cover Replacement: 步骤 4 中的图像 2,3 OnePlus 3 Back Cover Replacement: 步骤 4 中的图像 3,3
    • As you work, try not to accidentally power on the phone. If you do, turn the phone off before resuming disassembly.
    • Place a suction cup near the bottom edge of the display.
    • Pull on the suction cup with strong steady force.
    • Press the edge of an opening tool straight into the frame seam near the suction cup until the edge wedges between the plastic frame and the back cover's lip.
    • Due to tight tolerances, this will take substantial force. Using a new opening tool with an unmarred edge will help with this step.
    • Do not use metal tools, as they will most likely crack the screen.
  5. OnePlus 3 Back Cover Replacement: 步骤 5 中的图像 1,3 OnePlus 3 Back Cover Replacement: 步骤 5 中的图像 2,3 OnePlus 3 Back Cover Replacement: 步骤 5 中的图像 3,3
    • Once the opening tool's edge is wedged in position, carefully slide the tool along the bottom edge of the phone.
    • Carefully guide the opening tool around the left corner of the phone while keeping the tool's edge within the seam.
  6. OnePlus 3 Back Cover Replacement: 步骤 6 中的图像 1,2 OnePlus 3 Back Cover Replacement: 步骤 6 中的图像 2,2
    • Continue sliding the opening tool along the long edge, releasing the clips along the way.
    • The last clip in the top-left corner near the alert switch is recessed and can be difficult to release. Take your time and use the flat end of a spudger or an opening pick to help.
  7. OnePlus 3 Back Cover Replacement: 步骤 7 中的图像 1,3 OnePlus 3 Back Cover Replacement: 步骤 7 中的图像 2,3 OnePlus 3 Back Cover Replacement: 步骤 7 中的图像 3,3
    • With the bottom and left edge of the phone freed, gently wiggle the frame to release the top and right edge clips.
    • Lift the screen up and remove it.
    • During reassembly, pause here to test your phone's functionality before securing the back cover.
    • To reinstall the back cover:
    • Align the top edge of the frame to the back cover and ensure that the top clips slip into place.
    • Squeeze along the long edges of the phone to snap the remaining clips into place.
结论
Repair didn’t go as planned? Check out our OnePlus 3 Answers community for troubleshooting help.
5等其他人完成本指南。
Arthur Shi
于01/03/18注册
314,274 声望
创作了729篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 32
总计 22,814
