跳转到主内容
加入维修社区 - 创建账户
One Education Infinity:One Display Assembly Replacement
你所需要的
  1. One Education Infinity:One Display Assembly Replacement, Top Case: 步骤 1 中的图像 1,3 One Education Infinity:One Display Assembly Replacement, Top Case: 步骤 1 中的图像 2,3 One Education Infinity:One Display Assembly Replacement, Top Case: 步骤 1 中的图像 3,3
    • Insert a Jimmy or other prying tool into the seam between the screen and back case.
    • Trace around the edges until all clips are released.
    • Lift the back case away from the tablet.
    询问修复机器人
    添加评论
  2. One Education Infinity:One Display Assembly Replacement, Speaker: 步骤 2 中的图像 1,2 One Education Infinity:One Display Assembly Replacement, Speaker: 步骤 2 中的图像 2,2
    • Use a spudger to release the speaker wires by pushing the bundled cabled connector away from the motherboard.
    • Be sure to pull out the white connector instead of the individual wires to avoid damage to the device.
    询问修复机器人
    添加评论
  3. One Education Infinity:One Display Assembly Replacement: 步骤 3 中的图像 1,1
    • Use a spudger to lift the speakers out of the device.
    询问修复机器人
    添加评论
  4. One Education Infinity:One Display Assembly Replacement, Battery: 步骤 4 中的图像 1,2 One Education Infinity:One Display Assembly Replacement, Battery: 步骤 4 中的图像 2,2
    • Use a spudger to disconnect the black bundled cable connector from the motherboard.
    询问修复机器人
    添加评论
  5. One Education Infinity:One Display Assembly Replacement: 步骤 5 中的图像 1,3 One Education Infinity:One Display Assembly Replacement: 步骤 5 中的图像 2,3 One Education Infinity:One Display Assembly Replacement: 步骤 5 中的图像 3,3
    • Use a spudger to lift the black tab on top of the ZIF connector.
    • Slide the ribbon cable out of the connector.
    询问修复机器人
    添加评论
  6. One Education Infinity:One Display Assembly Replacement: 步骤 6 中的图像 1,3 One Education Infinity:One Display Assembly Replacement: 步骤 6 中的图像 2,3 One Education Infinity:One Display Assembly Replacement: 步骤 6 中的图像 3,3
    • Use a spudger to flip up the black retaining flap on the ZIF connector.
    • Pull the folded ribbon cable straight out of the connector.
    • This ribbon cable must be disconnected before removing the battery because it is attached to the battery with adhesive.
    询问修复机器人
    添加评论
  7. One Education Infinity:One Display Assembly Replacement: 步骤 7 中的图像 1,1
    • Use a spudger to pry the battery away from the device.
    • Always use ESD safe tools when working with delicate electrical components.
    询问修复机器人
    添加评论
  8. One Education Infinity:One Display Assembly Replacement, Antenna: 步骤 8 中的图像 1,2 One Education Infinity:One Display Assembly Replacement, Antenna: 步骤 8 中的图像 2,2
    在这个步骤中使用的工具:
    • Use ESD safe tweezers to disconnect the antenna from the motherboard.
    询问修复机器人
    添加评论
  9. One Education Infinity:One Display Assembly Replacement, Camera Assembly: 步骤 9 中的图像 1,3 One Education Infinity:One Display Assembly Replacement, Camera Assembly: 步骤 9 中的图像 2,3 One Education Infinity:One Display Assembly Replacement, Camera Assembly: 步骤 9 中的图像 3,3
    • Use a spudger to flip up the black flap on the camera's ZIF connector.
    • Pull the ribbon cable straight out of the connector.
    询问修复机器人
    添加评论
  10. One Education Infinity:One Display Assembly Replacement: 步骤 10 中的图像 1,2 One Education Infinity:One Display Assembly Replacement: 步骤 10 中的图像 2,2
    在这个步骤中使用的工具:
    • Use tweezers to remove the black cushion surrounding the camera lens.
    询问修复机器人
    添加评论
  11. One Education Infinity:One Display Assembly Replacement: 步骤 11 中的图像 1,2 One Education Infinity:One Display Assembly Replacement: 步骤 11 中的图像 2,2
    • Use tweezers to lift the camera assembly away from the device.
    • Lift straight up to avoid tearing the delicate ribbon cable on the retaining wall.
    询问修复机器人
    添加评论
  12. One Education Infinity:One Display Assembly Replacement, Motherboard: 步骤 12 中的图像 1,3 One Education Infinity:One Display Assembly Replacement, Motherboard: 步骤 12 中的图像 2,3 One Education Infinity:One Display Assembly Replacement, Motherboard: 步骤 12 中的图像 3,3
    询问修复机器人
    添加评论
  13. One Education Infinity:One Display Assembly Replacement: 步骤 13 中的图像 1,1
    在这个步骤中使用的工具:
    • Use tweezers to pull the dock connection cable away from the motherboard.
    询问修复机器人
    添加评论
  14. One Education Infinity:One Display Assembly Replacement: 步骤 14 中的图像 1,1
    • Use a Phillips #00 screwdriver to unscrew the two 3.4 mm screws.
    • Use a Phillips #000 screwdriver to unscrew the one 4.2mm screw.
    询问修复机器人
    添加评论
  15. One Education Infinity:One Display Assembly Replacement: 步骤 15 中的图像 1,1
    • Lift the protective shield away from the motherboard.
    询问修复机器人
    添加评论
  16. One Education Infinity:One Display Assembly Replacement: 步骤 16 中的图像 1,3 One Education Infinity:One Display Assembly Replacement: 步骤 16 中的图像 2,3 One Education Infinity:One Display Assembly Replacement: 步骤 16 中的图像 3,3
    • With the flat end of a spudger, flip up the black flap on the display's ZIF connector.
    • Insert the pointed end of the spudger between the cable and the motherboard and gently pull the cable straight out of the connector.
    • During reassembly, be sure to insert the cable into the connector up to the white line on the cable and then close the retaining flap.
    询问修复机器人
    添加评论
  17. One Education Infinity:One Display Assembly Replacement: 步骤 17 中的图像 1,1
    • Gently lift the motherboard away from the display assembly.
    询问修复机器人
    添加评论
  18. One Education Infinity:One Display Assembly Replacement, Display Assembly: 步骤 18 中的图像 1,1
    • Unscrew the five 4.2mm screws with a Phillips #000 screwdriver.
    询问修复机器人
    添加评论
  19. One Education Infinity:One Display Assembly Replacement: 步骤 19 中的图像 1,2 One Education Infinity:One Display Assembly Replacement: 步骤 19 中的图像 2,2
    • Peel the protective flap away from the display.
    询问修复机器人
    添加评论
  20. One Education Infinity:One Display Assembly Replacement: 步骤 20 中的图像 1,2 One Education Infinity:One Display Assembly Replacement: 步骤 20 中的图像 2,2
    • Use a spudger to lift the digitizer away from the screen.
    • Grasp the edge of the digitizer and lift straight up to remove.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
Taylor Bratsch
于09/06/16注册
6,159 声望
创作了14篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 19
总计 617
