跳转到主内容
加入维修社区 - 创建账户
One Education Infinity:One Camera Assembly Replacement
你所需要的
    1. One Education Infinity:One Camera Assembly Replacement, Battery: 步骤 1 中的图像 1,2 One Education Infinity:One Camera Assembly Replacement, Battery: 步骤 1 中的图像 2,2
      • Use a spudger to disconnect the black bundled cable connector from the motherboard.
      询问修复机器人
      添加评论
    2. One Education Infinity:One Camera Assembly Replacement: 步骤 2 中的图像 1,3 One Education Infinity:One Camera Assembly Replacement: 步骤 2 中的图像 2,3 One Education Infinity:One Camera Assembly Replacement: 步骤 2 中的图像 3,3
      • Use a spudger to lift the black tab on top of the ZIF connector.
      • Slide the ribbon cable out of the connector.
      询问修复机器人
      添加评论
    3. One Education Infinity:One Camera Assembly Replacement: 步骤 3 中的图像 1,3 One Education Infinity:One Camera Assembly Replacement: 步骤 3 中的图像 2,3 One Education Infinity:One Camera Assembly Replacement: 步骤 3 中的图像 3,3
      • Use a spudger to flip up the black retaining flap on the ZIF connector.
      • Pull the folded ribbon cable straight out of the connector.
      • This ribbon cable must be disconnected before removing the battery because it is attached to the battery with adhesive.
      询问修复机器人
      添加评论
    4. One Education Infinity:One Camera Assembly Replacement: 步骤 4 中的图像 1,1
      • Use a spudger to pry the battery away from the device.
      • Always use ESD safe tools when working with delicate electrical components.
      询问修复机器人
      添加评论
    1. One Education Infinity:One Camera Assembly Replacement, Camera Assembly: 步骤 5 中的图像 1,3 One Education Infinity:One Camera Assembly Replacement, Camera Assembly: 步骤 5 中的图像 2,3 One Education Infinity:One Camera Assembly Replacement, Camera Assembly: 步骤 5 中的图像 3,3
      • Use a spudger to flip up the black flap on the camera's ZIF connector.
      • Pull the ribbon cable straight out of the connector.
      询问修复机器人
      添加评论
    2. One Education Infinity:One Camera Assembly Replacement: 步骤 6 中的图像 1,2 One Education Infinity:One Camera Assembly Replacement: 步骤 6 中的图像 2,2
      在这个步骤中使用的工具:
      • Use tweezers to remove the black cushion surrounding the camera lens.
      询问修复机器人
      添加评论
    3. One Education Infinity:One Camera Assembly Replacement: 步骤 7 中的图像 1,2 One Education Infinity:One Camera Assembly Replacement: 步骤 7 中的图像 2,2
      • Use tweezers to lift the camera assembly away from the device.
      • Lift straight up to avoid tearing the delicate ribbon cable on the retaining wall.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
Taylor Bratsch
于09/06/16注册
6,168 声望
创作了14篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 12
过去 30 天: 31
总计 561
