跳转到主内容
加入维修社区 - 创建账户
One Education Infinity Touchpad Replacement
你所需要的
    1. One Education Infinity Touchpad Replacement, Back Case: 步骤 1 中的图像 1,3 One Education Infinity Touchpad Replacement, Back Case: 步骤 1 中的图像 2,3 One Education Infinity Touchpad Replacement, Back Case: 步骤 1 中的图像 3,3
      • Always power off your device before beginning disassembly.
      • Remove the screw covers and rubber feet from the bottom of the laptop with a metal spudger.
      询问修复机器人
      添加评论
    2. One Education Infinity Touchpad Replacement: 步骤 2 中的图像 1,2 One Education Infinity Touchpad Replacement: 步骤 2 中的图像 2,2
      • Using a Phillips #00 screwdriver, remove the sixteen 5.0 mm black screws from the back panel.
      询问修复机器人
      添加评论
    3. One Education Infinity Touchpad Replacement: 步骤 3 中的图像 1,3 One Education Infinity Touchpad Replacement: 步骤 3 中的图像 2,3 One Education Infinity Touchpad Replacement: 步骤 3 中的图像 3,3
      • Using the iFixit plastic opening tool or spudger, start near the white hinge of the device and lift along the outer edges of the device until all clips are released.
      • Lift the back case off of the device.
      • Removing the back may create a loud snapping noise.
      询问修复机器人
      添加评论
    1. One Education Infinity Touchpad Replacement, Battery: 步骤 4 中的图像 1,3 One Education Infinity Touchpad Replacement, Battery: 步骤 4 中的图像 2,3 One Education Infinity Touchpad Replacement, Battery: 步骤 4 中的图像 3,3
      • There may be black tape inside your device covering components or holding down wires. This tape is unimportant for the function of the device, and can be removed.
      • Carefully wiggle the battery cable to the right and out of the port with a plastic spudger.
      询问修复机器人
      添加评论
    2. One Education Infinity Touchpad Replacement: 步骤 5 中的图像 1,3 One Education Infinity Touchpad Replacement: 步骤 5 中的图像 2,3 One Education Infinity Touchpad Replacement: 步骤 5 中的图像 3,3
      • Wedge a plastic spudger underneath the battery from the upper edge and slide it carefully along the length of the battery to separate it from the case.
      • There is a mild adhesive holding down the battery. Take care not to puncture or excessively bend the battery while freeing it from the adhesive.
      • Lift the battery out from the internal case.
      询问修复机器人
      添加评论
    1. One Education Infinity Touchpad Replacement, Solid State Drive: 步骤 6 中的图像 1,3 One Education Infinity Touchpad Replacement, Solid State Drive: 步骤 6 中的图像 2,3 One Education Infinity Touchpad Replacement, Solid State Drive: 步骤 6 中的图像 3,3
      • Use a Phillips #00 screwdriver to remove the single 2mm black screw from the SSD.
      询问修复机器人
      添加评论
    2. One Education Infinity Touchpad Replacement: 步骤 7 中的图像 1,3 One Education Infinity Touchpad Replacement: 步骤 7 中的图像 2,3 One Education Infinity Touchpad Replacement: 步骤 7 中的图像 3,3
      • Grab the SSD with your fingers and slide it slowly to the right and out of its port.
      询问修复机器人
      添加评论
    1. One Education Infinity Touchpad Replacement, Motherboard: 步骤 8 中的图像 1,2 One Education Infinity Touchpad Replacement, Motherboard: 步骤 8 中的图像 2,2
      • Using your fingers, carefully pull the two ribbon cable locking clips out from their ports.
      询问修复机器人
      添加评论
    2. One Education Infinity Touchpad Replacement: 步骤 9 中的图像 1,1
      • Using your fingers, carefully lift up the black tab and then unplug the gold ribbon cable.
      询问修复机器人
      添加评论
    3. One Education Infinity Touchpad Replacement: 步骤 10 中的图像 1,1
      • Using a spudger, carefully unplug the black and grey wires by popping them up off the wireless card.
      询问修复机器人
      添加评论
    4. One Education Infinity Touchpad Replacement: 步骤 11 中的图像 1,1
      • Using your fingers, carefully unplug the two speaker wires from the motherboard.
      询问修复机器人
      添加评论
    5. One Education Infinity Touchpad Replacement: 步骤 12 中的图像 1,2 One Education Infinity Touchpad Replacement: 步骤 12 中的图像 2,2
      • Using your fingers or an iFixit opening tool, carefully lift the black tab on top of the ZIF connector and remove the ribbon cable.
      询问修复机器人
      添加评论
    6. One Education Infinity Touchpad Replacement: 步骤 13 中的图像 1,1
      • Using your fingers, carefully lift up the black tab and then unplug the blue ribbon cable.
      询问修复机器人
      添加评论
    7. One Education Infinity Touchpad Replacement: 步骤 14 中的图像 1,2 One Education Infinity Touchpad Replacement: 步骤 14 中的图像 2,2
      • Using a Phillips #00 screwdriver, remove the single 4 mm silver screw from beneath the ribbon cable.
      • Using a Phillips #00 screwdriver, remove the two 2.5 mm black screws.
      • Using your fingers, carefully lift the motherboard out of the internal panel.
      询问修复机器人
      添加评论
    1. One Education Infinity Touchpad Replacement, Touchpad: 步骤 15 中的图像 1,1
      • Using a Phillips #00 screwdriver, remove the four 2mm silver screws.
      询问修复机器人
      添加评论
    2. One Education Infinity Touchpad Replacement: 步骤 16 中的图像 1,2 One Education Infinity Touchpad Replacement: 步骤 16 中的图像 2,2
      • Peel back the black tape.
      • Using your fingers, carefully lift the metal plate out of the internal panel.
      询问修复机器人
      添加评论
    3. One Education Infinity Touchpad Replacement: 步骤 17 中的图像 1,1
      • Using a Phillips #00 screwdriver, remove the two 2mm silver screws.
      询问修复机器人
      添加评论
    4. One Education Infinity Touchpad Replacement: 步骤 18 中的图像 1,2 One Education Infinity Touchpad Replacement: 步骤 18 中的图像 2,2
      • Using your fingers, carefully lift the touch-pad out of the internal panel.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
Jason Childers
于10/10/19注册
109 声望
撰写一个指南
团队
Cal Poly, Team S11-G4, Regan Fall 2019 Cal Poly, Team S11-G4, Regan Fall 2019 的会员
CPSU-REGAN-F19S11G4
3 名成员
创作了28篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 11
过去 30 天: 31
总计 555
