跳转到主内容
加入维修社区 - 创建账户
Onda V701 Battery Replacement
你所需要的
    1. Onda V701 Battery Replacement, Back Panel: 步骤 1 中的图像 1,3 Onda V701 Battery Replacement, Back Panel: 步骤 1 中的图像 2,3 Onda V701 Battery Replacement, Back Panel: 步骤 1 中的图像 3,3
      • Ensure device is powered off before disassembly.
      • Remove the 4 rubber screw plugs using a spudger.
      询问修复机器人
      添加评论
    2. Onda V701 Battery Replacement: 步骤 2 中的图像 1,3 Onda V701 Battery Replacement: 步骤 2 中的图像 2,3 Onda V701 Battery Replacement: 步骤 2 中的图像 3,3
      • Remove the four 4.8mm mounting screws using a PH00 screwdriver.
      询问修复机器人
      添加评论
    3. Onda V701 Battery Replacement: 步骤 3 中的图像 1,2 Onda V701 Battery Replacement: 步骤 3 中的图像 2,2
      • Starting at one corner, gently pry the back panel assembly from the screen assembly using two plastic opening tools.
      • Slide the opening tools around the perimeter of the device to separate the back panel assembly from the screen assembly.
      询问修复机器人
      添加评论
    4. Onda V701 Battery Replacement: 步骤 4 中的图像 1,2 Onda V701 Battery Replacement: 步骤 4 中的图像 2,2
      • Gently lift the screen assembly away from the back cover assembly.
      • Be careful when separating the two pieces as the screen assembly is still connected to the mother board by two ribbon cables.
      询问修复机器人
      添加评论
    5. Onda V701 Battery Replacement: 步骤 5 中的图像 1,3 Onda V701 Battery Replacement: 步骤 5 中的图像 2,3 Onda V701 Battery Replacement: 步骤 5 中的图像 3,3
      • Disconnect the two ribbon connectors by flipping the gray tabs up with a fingernail or a spudger.
      • Remove the ribbon cables.
      询问修复机器人
      添加评论
    1. Onda V701 Battery Replacement, Battery: 步骤 6 中的图像 1,1
      在这个步骤中使用的工具:
      • Desolder the red(+) and black(-) wires connecting the battery to the motherboard using a soldering iron and tweezers to hold the wire.
      • Soldering requires a lot of heat. Do not touch the metal part of the soldering iron. Wear gloves if necessary to protect your hands. The fumes from soldering could also be toxic. Work in a well ventilated area and/or use a respirator.
      询问修复机器人
      添加评论
    2. Onda V701 Battery Replacement: 步骤 7 中的图像 1,3 Onda V701 Battery Replacement: 步骤 7 中的图像 2,3 Onda V701 Battery Replacement: 步骤 7 中的图像 3,3
      • Carefully pry the battery away from the back panel using the nylon or metal spudger.
      • Gently remove the battery from the back panel.
      • Ensure not to excessively bend or puncture the battery. Doing so could cause the battery to catch on fire or explode.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
团队
Colorado Springs, Team 4-6, Panko Spring 2015 Colorado Springs, Team 4-6, Panko Spring 2015 的会员
UCCS-PANKO-S15S4G6
3 名成员
创作了10篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 23
总计 1,269
