跳转到主内容
加入维修社区 - 创建账户
Olympus VR-350 Lens Box Unit Replacement
你所需要的
    1. Olympus VR-350 Lens Box Unit Replacement, Front Plate: 步骤 1 中的图像 1,2 Olympus VR-350 Lens Box Unit Replacement, Front Plate: 步骤 1 中的图像 2,2
      • Remove the two 4mm screws from each side of the camera with a Phillips PH000 screwdriver.
      询问修复机器人
      添加评论
    2. Olympus VR-350 Lens Box Unit Replacement: 步骤 2 中的图像 1,1
      • Remove the four 4mm screws from the bottom of the camera with a Phillips PH000 screwdriver.
      询问修复机器人
      添加评论
    3. Olympus VR-350 Lens Box Unit Replacement: 步骤 3 中的图像 1,3 Olympus VR-350 Lens Box Unit Replacement: 步骤 3 中的图像 2,3 Olympus VR-350 Lens Box Unit Replacement: 步骤 3 中的图像 3,3
      • Use the plastic opening tools and your fingers to pry the front plate from the camera.
      • You might need to open the battery cover to remove the front plate.
      询问修复机器人
      添加评论
    1. Olympus VR-350 Lens Box Unit Replacement, Back Plate: 步骤 4 中的图像 1,2 Olympus VR-350 Lens Box Unit Replacement, Back Plate: 步骤 4 中的图像 2,2
      • Use your fingers to pry open the back cover.
      • When you remove the back of the camera, the button membrane might fall out. Don’t lose this sheet.
      • The LCD screen is connected to the body of the camera by an orange ribbon cable. Don’t pull this ribbon cable out.
      询问修复机器人
      添加评论
    1. Olympus VR-350 Lens Box Unit Replacement, LCD Screen: 步骤 5 中的图像 1,2 Olympus VR-350 Lens Box Unit Replacement, LCD Screen: 步骤 5 中的图像 2,2
      • Using the Phillips PH000 screwdriver, remove the 4mm screw from the bottom left corner of the button plate located under the button membrane.
      询问修复机器人
      添加评论
    2. Olympus VR-350 Lens Box Unit Replacement: 步骤 6 中的图像 1,1
      • Pull the button pad up to fully reveal the visible ribbon cable.
      • You might need to bend the button pad out of the way.
      询问修复机器人
      添加评论
    3. Olympus VR-350 Lens Box Unit Replacement: 步骤 7 中的图像 1,1
      • Pull out the LCD screen and the ribbon cable.
      • The ribbon cable should be easy to pull out.
      询问修复机器人
      添加评论
    1. Olympus VR-350 Lens Box Unit Replacement, Lens Box Unit: 步骤 8 中的图像 1,1
      • Remove the metal plate that was underneath the LCD screen by removing the four 4 mm screws with the Phillips PH000 screwdriver.
      询问修复机器人
      添加评论
    2. Olympus VR-350 Lens Box Unit Replacement: 步骤 9 中的图像 1,2 Olympus VR-350 Lens Box Unit Replacement: 步骤 9 中的图像 2,2
      • Remove the orange ribbon cable from the connector on the left side of the motherboard.
      • To do this, gently lift up the small grey clasp and pull the cable ribbon.
      询问修复机器人
      添加评论
    3. Olympus VR-350 Lens Box Unit Replacement: 步骤 10 中的图像 1,1
      • There are two other small ribbon cables under the motherboard connected to the lens box. Pull them out from the motherboard.
      • You may need to use force to pull out the ribbon cables.
      询问修复机器人
      添加评论
    4. Olympus VR-350 Lens Box Unit Replacement: 步骤 11 中的图像 1,1
      • Pull the lens box up and out to remove it.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
5等其他人完成本指南。
Brooke
于02/23/15注册
278 声望
撰写一个指南
团队
USF Tampa, Team 1-3, Leahy Winter 2015 USF Tampa, Team 1-3, Leahy Winter 2015 的会员
USFT-LEAHY-W15S1G3
3 名成员
创作了10篇指南
1指南评论
Worked for a SH-21, with a couple of extra screws to remove. Thank you!
Rick Allies - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 10
过去 30 天: 46
总计 2,359
