跳转到主内容
加入维修社区 - 创建账户
Olympus FE-210 Lens Assembly Replacement
你所需要的
    1. Olympus FE-210 Lens Assembly Replacement, Battery: 步骤 1 中的图像 1,2 Olympus FE-210 Lens Assembly Replacement, Battery: 步骤 1 中的图像 2,2
      • The battery compartment is located on the bottom side of the camera. Push the button in, and slide the cover to get access to the batteries.
      询问修复机器人
      添加评论
    2. Olympus FE-210 Lens Assembly Replacement: 步骤 2 中的图像 1,2 Olympus FE-210 Lens Assembly Replacement: 步骤 2 中的图像 2,2
      • The batteries will slide right out.
      • When putting new batteries in, make sure they are pointing the right direction.
      询问修复机器人
      添加评论
    1. Olympus FE-210 Lens Assembly Replacement, Front Casing: 步骤 3 中的图像 1,3 Olympus FE-210 Lens Assembly Replacement, Front Casing: 步骤 3 中的图像 2,3 Olympus FE-210 Lens Assembly Replacement, Front Casing: 步骤 3 中的图像 3,3
      • Remove the seven screws holding the front case in place, with a Phillips #00 screwdriver.
      • Six screws are 3.6 mm.
      • The seventh screw is 3.2 mm.
      询问修复机器人
      添加评论
    2. Olympus FE-210 Lens Assembly Replacement: 步骤 4 中的图像 1,3 Olympus FE-210 Lens Assembly Replacement: 步骤 4 中的图像 2,3 Olympus FE-210 Lens Assembly Replacement: 步骤 4 中的图像 3,3
      • Insert an opening tool or spudger into the seam between the front case and body of the camera to release the clips holding it together.
      • These three places are located:
      • At the top and bottom of the battery side (opposite of side pictured) of the case.
      • Right in the middle of the DC-in side (side pictured) of the case.
      • Top of the camera, to the left of the power button.
      • Once those places are disconnected, the front case will pop right off.
      • The camera in the first two pictures is upside down. This is the best position to place your thumbs to remove the case.
      询问修复机器人
      添加评论
    1. Olympus FE-210 Lens Assembly Replacement, Rear Casing: 步骤 5 中的图像 1,1
      • Remove the 3.2 mm screw in the battery compartment using a #00 screwdriver.
      • After removal of the screw the case will be loose, but do not tug it off. There is a cord connecting the rear controls to the motherboard.
      询问修复机器人
      添加评论
    2. Olympus FE-210 Lens Assembly Replacement: 步骤 6 中的图像 1,3 Olympus FE-210 Lens Assembly Replacement: 步骤 6 中的图像 2,3 Olympus FE-210 Lens Assembly Replacement: 步骤 6 中的图像 3,3
      • Carefully pull the rear case away from the camera until you have access to the cord connected to the motherboard.
      • Lift the white latch using a fingernail or a spudger.
      • Pull the cord from its connector.
      询问修复机器人
      添加评论
    1. Olympus FE-210 Lens Assembly Replacement, Motherboard: 步骤 7 中的图像 1,2 Olympus FE-210 Lens Assembly Replacement, Motherboard: 步骤 7 中的图像 2,2
      • Remove the 2 pieces of translucent yellow tape.
      • Removing these pieces of tape will void the camera warranty. They serve no functional purpose and do not need to be replaced during reassembly.
      询问修复机器人
      添加评论
    2. Olympus FE-210 Lens Assembly Replacement: 步骤 8 中的图像 1,2 Olympus FE-210 Lens Assembly Replacement: 步骤 8 中的图像 2,2
      • Remove the seven 2.7 mm using a #00 screwdriver.
      询问修复机器人
      添加评论
    3. Olympus FE-210 Lens Assembly Replacement: 步骤 9 中的图像 1,1
      在这个步骤中使用的工具:
      • Remove the ribbon cord located near the top right corner of the motherboard. Do this by carefully pulling the cord out of the socket using a pair of tweezers.
      询问修复机器人
      添加评论
    4. Olympus FE-210 Lens Assembly Replacement: 步骤 10 中的图像 1,1
      • Disconnect the ribbon cord located on the left side of the motherboard.
      • Use tweezers or a spudger to lift the latch on the connector.
      • Carefully remove the cord from the connector.
      询问修复机器人
      添加评论
    5. Olympus FE-210 Lens Assembly Replacement: 步骤 11 中的图像 1,2 Olympus FE-210 Lens Assembly Replacement: 步骤 11 中的图像 2,2
      • De-solder the 2 connection points.
      • Be careful to not damage any part of the circuit board with the soldering iron.
      询问修复机器人
      添加评论
    6. Olympus FE-210 Lens Assembly Replacement: 步骤 12 中的图像 1,1
      • Remove the motherboard from the camera casing.
      询问修复机器人
      添加评论
    1. Olympus FE-210 Lens Assembly Replacement, Lens Assembly: 步骤 13 中的图像 1,1
      • Remove the three 3.6 mm screws using a #00 screwdriver.
      询问修复机器人
      添加评论
    2. Olympus FE-210 Lens Assembly Replacement: 步骤 14 中的图像 1,2 Olympus FE-210 Lens Assembly Replacement: 步骤 14 中的图像 2,2
      • Slide the lens to the left and pull up. The lens should easily come loose and slide right out.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
Matt
于01/25/11注册
826 声望
创作了6篇指南
团队
Cal Poly, Team 4-36, Regan Winter 2011 Cal Poly, Team 4-36, Regan Winter 2011 的会员
CPSU-REGAN-W11S4G36
3 名成员
创作了14篇指南
1指南评论
This is also applicable to the Olympus FE170. I dismantled and repaired mine using this guide. Excellent!
Alan Shaw - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 11
过去 30 天: 60
总计 7,277
