跳转到主内容
加入维修社区 - 创建账户
Olympus Digital Camera TG-3 Shutter Button Replacement
你所需要的
    1. Olympus Digital Camera TG-3 Shutter Button  Replacement, Front Case: 步骤 1 中的图像 1,1
      • Locate the strap eyelet side of the camera and use the PH000 screwdriver to remove the two 5.3mm screws that hold the strap.
      询问修复机器人
      添加评论
    2. Olympus Digital Camera TG-3 Shutter Button  Replacement: 步骤 2 中的图像 1,1
      • Locate the side of the camera containing the HDMI port. Use the PH000 screwdriver to remove the 5.4mm screw located on the lower left side below the port.
      询问修复机器人
      添加评论
    3. Olympus Digital Camera TG-3 Shutter Button  Replacement: 步骤 3 中的图像 1,1
      • Using the PH000 screwdriver, remove the 3.8mm screw located inside the HDMI port.
      询问修复机器人
      添加评论
    4. Olympus Digital Camera TG-3 Shutter Button  Replacement: 步骤 4 中的图像 1,1
      • Locate the bottom section of the camera. Using the PH000 screwdriver, remove the two 4mm screws located towards the middle (near the battery compartment).
      询问修复机器人
      添加评论
    5. Olympus Digital Camera TG-3 Shutter Button  Replacement: 步骤 5 中的图像 1,1
      • Now you should be able to remove the front case easily using your hand.
      询问修复机器人
      添加评论
    1. Olympus Digital Camera TG-3 Shutter Button  Replacement, Back Case: 步骤 6 中的图像 1,1
      • Using the PH000 screwdriver, remove the two 4mm screws located on the left side of the camera, under the strap holder.
      询问修复机器人
      添加评论
    2. Olympus Digital Camera TG-3 Shutter Button  Replacement: 步骤 7 中的图像 1,1
      • Use a PH000 screwdriver to remove the 3 mm screw located on the bottom of the battery compartment.
      询问修复机器人
      添加评论
    3. Olympus Digital Camera TG-3 Shutter Button  Replacement: 步骤 8 中的图像 1,1
      • Hold the device as shown in the picture. Using the PH000 screwdriver, remove the 9mm screw located on the upper left side of the camera.
      询问修复机器人
      添加评论
    4. Olympus Digital Camera TG-3 Shutter Button  Replacement: 步骤 9 中的图像 1,1
      • Use the PH000 screwdriver to remove the 7mm screw you'll find toward the lower left side of the camera.
      询问修复机器人
      添加评论
    5. Olympus Digital Camera TG-3 Shutter Button  Replacement: 步骤 10 中的图像 1,1
      • Use a PH000 screwdriver to remove the 6mm screw on the upper right side of the camera, above the flash.
      询问修复机器人
      添加评论
    6. Olympus Digital Camera TG-3 Shutter Button  Replacement: 步骤 11 中的图像 1,1
      • Using the PH000 screwdriver, remove the 1.2 mm located on the lower right side of the device, towards the corner.
      询问修复机器人
      添加评论
    7. Olympus Digital Camera TG-3 Shutter Button  Replacement: 步骤 12 中的图像 1,1
      • Use the PH0000 screwdriver to remove the 7 mm located on the upper side of the camera, where the shutter and zoom bottoms are. You will find the screw towards the middle of this section.
      询问修复机器人
      添加评论
    8. Olympus Digital Camera TG-3 Shutter Button  Replacement: 步骤 13 中的图像 1,1
      • Remove the back case using your hand.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
4等其他人完成本指南。
团队
USF Tampa, Team 1-6, Leahy Fall 2016 USF Tampa, Team 1-6, Leahy Fall 2016 的会员
USFT-LEAHY-F16S1G6
3 名成员
创作了10篇指南
2指南评论
Bravo super tutorial, but how to ensure the sealing after disassembly and reassembly?
vincent vidal - 回复 分享
I have a problem recovering the original condition. Is it possible Someone help me to restore it. Olympus TG-3 contact back. Witrocker@hotmail.com
Dawis rocker - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 12
过去 30 天: 64
总计 4,395
