跳转到主内容
加入维修社区 - 创建账户
Ohmeda Engström Display Unit Screen Replacement
医疗设备
iFixit 或本维修指南均未获得医疗设备制造商的认可或与任何制造商存在附属关系。
你所需要的
    1. Ohmeda Engström Display Unit Screen Replacement, Display Unit Screen: 步骤 1 中的图像 1,1
      • Turn off display unit, the power is located on the top left
      询问修复机器人
      添加评论
    2. Ohmeda Engström Display Unit Screen Replacement: 步骤 2 中的图像 1,1
      • Place the Display Unit face down on an anti-static pad. Make sure that the release tabs are fully depressed.
      • Loosen four screws (L) on each side of the display unit.
      • Remove the rear enclosure and you will be able to see: the fan (26), the connector panel assembly (21), the encoder assembly (12), the battery (5), the speaker (20), and the gasket(28)
      询问修复机器人
      添加评论
    3. Ohmeda Engström Display Unit Screen Replacement: 步骤 3 中的图像 1,1
      • Next, unplug all five wires from the display unit screen. These wires are labeled A, B, C, D, E.
      • Unscrew ten screws that are circled on the image.
      询问修复机器人
      添加评论
    4. Ohmeda Engström Display Unit Screen Replacement: 步骤 4 中的图像 1,1
      • Disconect the backlight harness (G)
      • Slide Grommet (H) out of the mounting plate slot
      • Remove four screws that support the mounting plate
      询问修复机器人
      添加评论
    5. Ohmeda Engström Display Unit Screen Replacement: 步骤 5 中的图像 1,1
      • Lift the the LCD display away from the mounting plate. Pull some of the display ribbon cable (I) to the top side of the plate. Flip the LCD over to the left of the assembly
      • Disconnect the ribbon cable (J)
      • When replacing the LCD, pull the excess ribbon cable toward the bottom side of the plate as you lower the LCD on to the plate
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
ryan love
于04/07/20注册
156 声望
撰写一个指南
团队
Cal Poly, Team S7-G6, Paton Spring 2020 Cal Poly, Team S7-G6, Paton Spring 2020 的会员
CPSU-PATON-S20S7G6
3 名成员
创作了3篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 26
总计 480
