跳转到主内容
加入维修社区 - 创建账户
Oculus Rift DK1 Display Replacement
你所需要的
    1. Oculus Rift DK1 Display Replacement, Lens: 步骤 1 中的图像 1,2 Oculus Rift DK1 Display Replacement, Lens: 步骤 1 中的图像 2,2
      • To remove the lenses, turn the right lens clockwise a quarter turn and the left lens counter-clockwise a quarter turn.
      询问修复机器人
      添加评论
    1. Oculus Rift DK1 Display Replacement, Display: 步骤 2 中的图像 1,2 Oculus Rift DK1 Display Replacement, Display: 步骤 2 中的图像 2,2
      • Use a Phillips #01 screwdriver to unscrew the four 9 mm Phillips #01 screws. (Two screws are shown in the picture, and two more screws are on the left side across from the right screws.)
      询问修复机器人
      添加评论
    2. Oculus Rift DK1 Display Replacement: 步骤 3 中的图像 1,3 Oculus Rift DK1 Display Replacement: 步骤 3 中的图像 2,3 Oculus Rift DK1 Display Replacement: 步骤 3 中的图像 3,3
      • Carefully lift the headstrap from the display. The two parts should separate easily enough with some force.
      • Once the headstrap assembly and display box are separated, the headstrap assembly can be set aside. You will be working with the display box for the rest of this guide!
      询问修复机器人
      添加评论
    3. Oculus Rift DK1 Display Replacement: 步骤 4 中的图像 1,2 Oculus Rift DK1 Display Replacement: 步骤 4 中的图像 2,2
      • Using the plastic opening tool, pry open the display box to reveal the LCD (Liquid Crystal Display) screen. Run the plastic opening tool around all four edges. Prying open the box may take a good amount of force.
      询问修复机器人
      添加评论
    4. Oculus Rift DK1 Display Replacement: 步骤 5 中的图像 1,3 Oculus Rift DK1 Display Replacement: 步骤 5 中的图像 2,3 Oculus Rift DK1 Display Replacement: 步骤 5 中的图像 3,3
      • Run the plastic opening tool along the bottom edge under the LCD screen to separate the adhesive holding the LCD to the display box.
      • Lift the screen up to reveal the wires and circuit board.
      • Ensure that all wires are in the right place upon reassembly.
      询问修复机器人
      添加评论
    5. Oculus Rift DK1 Display Replacement: 步骤 6 中的图像 1,2 Oculus Rift DK1 Display Replacement: 步骤 6 中的图像 2,2
      • Remove the wires from the circuit board on the LCD display using your fingernail or a plastic opening tool. This may take some pushing and pulling of the plastic piece.
      • Don't pull on the wires! Be sure to only pry the plastic part.
      • You can now completely separate the LCD screen from the rest of the device!
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
5等其他人完成本指南。
团队
Cal Poly, Team 70-5, Forte Winter 2015 Cal Poly, Team 70-5, Forte Winter 2015 的会员
CPSU-FORTE-W15S70G5
4 名成员
创作了24篇指南
1指南评论
testtesttesttest
d
cybname - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 12
过去 30 天: 43
总计 4,307
