简介
The spring inside your ORFELD EV-660’s power button may need to be replaced if pushing the power button fails to turn on the vacuum or causes the button to get stuck. This guide will show you how to replace the power button’s old spring.
This guide requires you to disassemble your vacuum. Work in a clear area to avoid losing detached parts.
Before you begin this repair, make sure the vacuum is powered off and unplugged from the charger.
你所需要的
Separate the dust cover and the motor from the vacuum body by pressing the eject button.
