跳转到主内容
加入维修社区 - 创建账户
Nvidia Shield Pro Android TV Hard Drive Replacement
你所需要的
    1. Nvidia Shield Pro Android TV Hard Drive Replacement, Bottom Cover: 步骤 1 中的图像 1,2 Nvidia Shield Pro Android TV Hard Drive Replacement, Bottom Cover: 步骤 1 中的图像 2,2
      • Flip to the back side of your Nvidia Shield Pro Android TV.
      • To open the bottom cover of the Nvidia Shield, start from the corner and slide your plastic opening tool across the gap.
      • If using a plastic opening tool to open the bottom cover is difficult, try using a metal spudger.
      询问修复机器人
      添加评论
    1. Nvidia Shield Pro Android TV Hard Drive Replacement, Hard Drive: 步骤 2 中的图像 1,3 Nvidia Shield Pro Android TV Hard Drive Replacement, Hard Drive: 步骤 2 中的图像 2,3 Nvidia Shield Pro Android TV Hard Drive Replacement, Hard Drive: 步骤 2 中的图像 3,3
      • Remove the two pieces of adhesives found at the top and the bottom side of the hard drive.
      • Put the two adhesives aside. Make sure to keep them flat so that you can put them back on after.
      询问修复机器人
      添加评论
    2. Nvidia Shield Pro Android TV Hard Drive Replacement: 步骤 3 中的图像 1,3 Nvidia Shield Pro Android TV Hard Drive Replacement: 步骤 3 中的图像 2,3 Nvidia Shield Pro Android TV Hard Drive Replacement: 步骤 3 中的图像 3,3
      • Detach the pack of wires by pulling it away from the socket.
      询问修复机器人
      添加评论
    3. Nvidia Shield Pro Android TV Hard Drive Replacement: 步骤 4 中的图像 1,3 Nvidia Shield Pro Android TV Hard Drive Replacement: 步骤 4 中的图像 2,3 Nvidia Shield Pro Android TV Hard Drive Replacement: 步骤 4 中的图像 3,3
      • Next to the empty socket where the black wires were attached to the I/O board (refer back to Step 2), detach the plastic strap from the I/O board by pushing the strap away from the socket using your finger.
      添加评论
    4. Nvidia Shield Pro Android TV Hard Drive Replacement: 步骤 5 中的图像 1,2 Nvidia Shield Pro Android TV Hard Drive Replacement: 步骤 5 中的图像 2,2
      • Remove the screw on the metal piece using a T6 Torx screwdriver and put away the metal piece after removing the screw.
      询问修复机器人
      添加评论
    5. Nvidia Shield Pro Android TV Hard Drive Replacement: 步骤 6 中的图像 1,1
      • Gently pull the hard drive out of the device.
      添加评论
结论
取消:我没有完成这个指南。
6等其他人完成本指南。
Jimmy Chen
于01/23/20注册
753 声望
创作了3篇指南
团队
Cal Poly, Team S18-G2, White Winter 2020 Cal Poly, Team S18-G2, White Winter 2020 的会员
CPSU-WHITE-W20S18G2
4 名成员
创作了26篇指南
5指南评论
The problem with this, is after replacing the Malfunctioning or Corrupted drive that will not solve the problem.
The device still will not run if there’s no Software or Firmware installed onto the new drive.
Can iFixit include that procedure of getting the new drive running.
Because you cannot clone a corrupt or bad drive .
Dennis Teague - 回复 分享
You took the words right out of my mouth. I have read the Nvidia website on how to do this but some of it is over my head. We need a flash for dummies to make sure we do it correctly!
Larry - 回复 分享
ok and now what??? nothing happens… there is no image on the new disk… how do i get it to boot? just stays on green light with no image on screen no boot
John Feathers - 回复 分享
I agree with John, please describe how to flash the image on the new drive.
Mario Martinez - 回复 分享
Hello everyone,
Since its an android device, steps are similar in flashing an android phone.
I found this, hope it helps!
steps:
https://developer.download.nvidia.com/as...
images:
https://developer.nvidia.com/shield-deve...
ContactLeft - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 21
过去 30 天: 119
总计 9,236
