跳转到主内容
加入维修社区 - 创建账户
Nvidia Shield Display Assembly Replacement
你所需要的
    1. Nvidia Shield Display Assembly Replacement, Remove Front Panel: 步骤 1 中的图像 1,3 Nvidia Shield Display Assembly Replacement, Remove Front Panel: 步骤 1 中的图像 2,3 Nvidia Shield Display Assembly Replacement, Remove Front Panel: 步骤 1 中的图像 3,3
      • Remove the seven 6.4mm T5 Torx screws from the back panel.
      • Use the spudger to separate the front and back panels.
      添加评论
    2. Nvidia Shield Display Assembly Replacement, Remove Green Grill: 步骤 2 中的图像 1,2 Nvidia Shield Display Assembly Replacement, Remove Green Grill: 步骤 2 中的图像 2,2
      • The green grill is not screwed in so it can be pulled right out.
      询问修复机器人
      添加评论
    3. Nvidia Shield Display Assembly Replacement, Remove Battery Cables: 步骤 3 中的图像 1,3 Nvidia Shield Display Assembly Replacement, Remove Battery Cables: 步骤 3 中的图像 2,3 Nvidia Shield Display Assembly Replacement, Remove Battery Cables: 步骤 3 中的图像 3,3
      • Remove the six 6.5mm T5 Torx screws.
      • Disconnect the power wires.
      • Peel back the copper tape and disconnect the black and white wires.
      询问修复机器人
      添加评论
    4. Nvidia Shield Display Assembly Replacement, Remove Battery Apparatus: 步骤 4 中的图像 1,1
      • Pull the battery apparatus out once all cables are removed.
      询问修复机器人
      添加评论
    1. Nvidia Shield Display Assembly Replacement, Removing Fan: 步骤 5 中的图像 1,3 Nvidia Shield Display Assembly Replacement, Removing Fan: 步骤 5 中的图像 2,3 Nvidia Shield Display Assembly Replacement, Removing Fan: 步骤 5 中的图像 3,3
      • Cooling is important for electronics, the last thing they want is to overheat.
      • Remove the two 7.3mm and four 8.4mm T5 Torx screws and disconnect the power cable.
      • Lift the fan free after the screws and cable are removed.
      询问修复机器人
      添加评论
    1. Nvidia Shield Display Assembly Replacement, Disconnecting from logic board: 步骤 6 中的图像 1,1
      • On the left side from where the display is attached to the back panel there is one 3.8mm T5 Torx screw that needs to be removed.
      • Once removed, the display should be able to be detached.
      添加评论
结论
取消:我没有完成这个指南。
5等其他人完成本指南。
团队
USF Tampa, Team 1-1, Hickman Fall 2014 USF Tampa, Team 1-1, Hickman Fall 2014 的会员
USFT-HICKMAN-F14S1G1
4 名成员
创作了66篇指南
1指南评论
Where can o get a replacement screen
jorge valenzuela - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 11
过去 30 天: 60
总计 7,258
