简介
Circuit boards short out or break down over time. Sometimes, there are simply enough broken items on the circuitboard that warrant replacing it entirely. This guide will show you how to properly and safely do so.
你所需要的
Turn the Numark N4 over so that the bottom panel is facing upwards.
Loosen and remove the 17 12mm screws from the bottom panel using a Phillips #2 screwdriver.
Loosen and remove the five 12mm screws from the circuit board using a Phillips #2 screwdriver.
3等其他人完成本指南。
