跳转到主内容
NuVision TM800A510L Screen Replacement
你所需要的
  1. NuVision TM800A510L Screen Replacement, Screen: 步骤 1 中的图像 1,2 NuVision TM800A510L Screen Replacement, Screen: 步骤 1 中的图像 2,2
    • Use a Heat Gun to heat the sides of the device and loosen the adhesive.
    • Heat the adhesive/device to just barely too hot to touch.
    • Pry up the the back of the device.
    • This process works best if you go one side at a time.
  2. NuVision TM800A510L Screen Replacement: 步骤 2 中的图像 1,1
  3. NuVision TM800A510L Screen Replacement: 步骤 3 中的图像 1,1
    • Peel this connector off the device.
    • This is basically just a sticker, but go slow so you don't tear the connector.
  4. NuVision TM800A510L Screen Replacement: 步骤 4 中的图像 1,1
    • Slowly pull the speaker out of its bed.
    • The speaker piece is glued down.
  5. NuVision TM800A510L Screen Replacement: 步骤 5 中的图像 1,2 NuVision TM800A510L Screen Replacement: 步骤 5 中的图像 2,2
    • If you have not done so already, de-solder the boards from the device.
    • De-soldering the wires right now makes sure none of the wires are damaged or broken when we move the components.
  6. NuVision TM800A510L Screen Replacement: 步骤 6 中的图像 1,1
    • The touch screen should lift right out of the device.
  7. NuVision TM800A510L Screen Replacement: 步骤 7 中的图像 1,1
    • Use the Heat Gun to heat the adhesive between the screen and edge protector.
    • Pry the two pieces apart.
    • Be careful of the circuit ribbon for the touch screen when prying the two pieces apart. The ribbon threads through both pieces.
    • Remember: Heating the device to 'almost to hot to touch' makes the process easier to work with.
    • Tip: Try the heating & prying process on one side of the device at a time.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 12
过去 30 天: 15
总计 2,401
