跳转到主内容
NuVision TM800A510L Charging Port Replacement
你所需要的
  1. NuVision TM800A510L Charging Port Replacement, Charging Port: 步骤 1 中的图像 1,2 NuVision TM800A510L Charging Port Replacement, Charging Port: 步骤 1 中的图像 2,2
    • Use a Heat Gun to loosen the adhesive on the underside of the back cover.
    • Use some prying tools to lift the back cover off of the device.
    • I recommend heating up the device up to 'just barely too hot to touch' and then prying sides up one at a time.
    • Although, you can use either plastic or metal prying tools, metal prying tools may scratch the device. Make sure not to damage power and volume buttons when prying the cover off as well.
  2. NuVision TM800A510L Charging Port Replacement: 步骤 2 中的图像 1,1
    • Unscrew the motherboard.
  3. NuVision TM800A510L Charging Port Replacement: 步骤 3 中的图像 1,1
    • Make sure all ribbons are disconnected.
  4. NuVision TM800A510L Charging Port Replacement: 步骤 4 中的图像 1,2 NuVision TM800A510L Charging Port Replacement: 步骤 4 中的图像 2,2
    • Desolder the Motherboard- this will make it easier to get to the charging port without breaking any cords.
    • Flip the Motherboard over and desolder the charging port from Motherboard.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 25
总计 1,980
