跳转到主内容
NuVision TM800A510L Rear Camera Replacement
你所需要的
  1. NuVision TM800A510L Rear Camera Replacement, Rear Camera: 步骤 1 中的图像 1,2 NuVision TM800A510L Rear Camera Replacement, Rear Camera: 步骤 1 中的图像 2,2
    • Use a Heat Gun to heat the sides of the device one at a time. The Heat Gun will loosen the adhesive.
    • Use thin tools to pry the back of the device off.
    • Metal tools may work best but may also scratch the device. Plastic prying tools can also be used.
    • Be careful around the power and volume buttons.
  2. NuVision TM800A510L Rear Camera Replacement: 步骤 2 中的图像 1,1
    • There are two different cameras and each have different ribbons.
    • Unlock both ribbons by flipping the black bar up.
  3. NuVision TM800A510L Rear Camera Replacement: 步骤 3 中的图像 1,2 NuVision TM800A510L Rear Camera Replacement: 步骤 3 中的图像 2,2
    • The camera facing towards the table lifts out easily, so go ahead and take that one out.
    • This works out well, if this is the camera you are most concerned about.
    • If you are more concerned the one facing you, move on to the next step.
  4. NuVision TM800A510L Rear Camera Replacement: 步骤 4 中的图像 1,2 NuVision TM800A510L Rear Camera Replacement: 步骤 4 中的图像 2,2
    • This camera is held down with adhesive, so you must be careful when prying it.
    • GO SLOW!
    • Camera pulls up and out of its slot easily.
结论
Be advised that you will need to replace the adhesive.
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 11
总计 400
