跳转到主内容
加入维修社区 - 创建账户
Nook Tablet Midframe Replacement
你所需要的
    1. Nook Tablet Midframe Replacement, Back Cover: 步骤 1 中的图像 1,1
      • Flip the Nook over.
      询问修复机器人
      添加评论
    2. Nook Tablet Midframe Replacement: 步骤 2 中的图像 1,2 Nook Tablet Midframe Replacement: 步骤 2 中的图像 2,2
      • Lift the flap that reads "Nook" to reveal the tape that is underneath. Remove the memory card if one is present.
      • Remove the tape covering the round holes to reveal two T5 Torx screws.
      • Remove the two T5 Torx screws securing the back cover.
      添加评论
    3. Nook Tablet Midframe Replacement: 步骤 3 中的图像 1,2 Nook Tablet Midframe Replacement: 步骤 3 中的图像 2,2
      • Insert the flat end of a spudger between the front panel and the rear assembly.
      • Though these photos show a screwdriver, use a spudger or plastic opening tool in order to prevent damage to the device.
      • Use a spudger to lift the the back panel from the rest of the Nook.
      询问修复机器人
      添加评论
    4. Nook Tablet Midframe Replacement: 步骤 4 中的图像 1,2 Nook Tablet Midframe Replacement: 步骤 4 中的图像 2,2
      • Slide the spudger around the edges of the Nook to loosen the back panel.
      询问修复机器人
      添加评论
    5. Nook Tablet Midframe Replacement: 步骤 5 中的图像 1,1
      • Pull the back panel off the Nook.
      询问修复机器人
      添加评论
    1. Nook Tablet Midframe Replacement, Screen Bezel: 步骤 6 中的图像 1,2 Nook Tablet Midframe Replacement, Screen Bezel: 步骤 6 中的图像 2,2
      • Using the T5 Torx screwdriver, remove the ten T5 screws from around the edges of the silver midframe.
      询问修复机器人
      添加评论
    2. Nook Tablet Midframe Replacement: 步骤 7 中的图像 1,2 Nook Tablet Midframe Replacement: 步骤 7 中的图像 2,2
      • Using a spudger or plastic opening tool, carefully pry the screen bezel away from the silver midframe.
      询问修复机器人
      添加评论
    1. Nook Tablet Midframe Replacement, Disconnect the Battery: 步骤 8 中的图像 1,2 Nook Tablet Midframe Replacement, Disconnect the Battery: 步骤 8 中的图像 2,2
      • Lift up the foam pad at the corner of the battery to reveal the battery connector.
      • Use a spudger or plastic opening tool to disconnect the battery cable from the motherboard.
      • These photos show a screwdriver, but we recommend using a nonconductive tool like a spudger to prevent a potential short.
      询问修复机器人
      添加评论
    1. Nook Tablet Midframe Replacement, Midframe: 步骤 9 中的图像 1,1
      • Lift up the foam that covers the power connector and volume connector.
      • Disconnect the power and volume cables from their sockets on the motherboard.
      询问修复机器人
      添加评论
    2. Nook Tablet Midframe Replacement: 步骤 10 中的图像 1,2 Nook Tablet Midframe Replacement: 步骤 10 中的图像 2,2
      • Carefully lift the silver midframe away from the motherboard and display assembly.
      • Be careful when handling the motherboard, making sure to not dislodge/shift any of its major components.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
Holly Lowe
于09/26/12注册
238 声望
创作了3篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 20
总计 763
