跳转到主内容
加入维修社区 - 创建账户
Nokia XL Dual Sim Battery Replacement
你所需要的
  1. Nokia XL Dual Sim Battery Replacement, Replacing the battery: 步骤 1 中的图像 1,3 Nokia XL Dual Sim Battery Replacement, Replacing the battery: 步骤 1 中的图像 2,3 Nokia XL Dual Sim Battery Replacement, Replacing the battery: 步骤 1 中的图像 3,3
    • Shut off the device completely.
    • Separate the back cover from the device by gently prying the opening out at the loose locations.
    • Gently pry open each side of the device at the indicated locations. It is best to use a plastic opening tool or similar item.
    询问修复机器人
    添加评论
  2. Nokia XL Dual Sim Battery Replacement, Battery Removal: 步骤 2 中的图像 1,2 Nokia XL Dual Sim Battery Replacement, Battery Removal: 步骤 2 中的图像 2,2
    • Once the back cover is removed, the battery will be in plain sight.
    • Again, use the plastic opening tool to lift the battery. From there, you can simply remove it.
    询问修复机器人
    添加评论
  3. Nokia XL Dual Sim Battery Replacement: 步骤 3 中的图像 1,1
    • You will now take your new battery and insert it into its designated location. Make sure to look at the position the battery was in before you took it out so you don't damage any of it's important parts.
    • Please be aware that your new battery may need to be charged first in order for your device to power back on.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
2等其他人完成本指南。
Shadeed Bilal
于09/25/14注册
231 声望
创作了4篇指南
团队
USF Tampa, Team 1-4, Brown Fall 2014 USF Tampa, Team 1-4, Brown Fall 2014 的会员
USFT-BROWN-F14S1G4
3 名成员
创作了21篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 28
总计 2,917
