跳转到主内容
加入维修社区 - 创建账户
Nokia XL Dual SIM Disassembly
仅作为前提条件
本指南仅提供前提条件!本指南是另一个程序的一部分,不能单独使用。
你所需要的
  1. Nokia XL Dual SIM Disassembly, Back Cover Removal: 步骤 1 中的图像 1,1
    • You will first need to separate the back cover from the device.
    • Gently pry open each side of the device at the indicated locations. It is best to use a plastic opening tool or similar tool.
    询问修复机器人
    添加评论
  2. Nokia XL Dual SIM Disassembly, Battery Removal: 步骤 2 中的图像 1,2 Nokia XL Dual SIM Disassembly, Battery Removal: 步骤 2 中的图像 2,2
    • Remove the back cover.
    • Use a plastic opening tool to lift the battery. Then, remove it.
    询问修复机器人
    添加评论
  3. Nokia XL Dual SIM Disassembly, Screen Separation part 1: 步骤 3 中的图像 1,2 Nokia XL Dual SIM Disassembly, Screen Separation part 1: 步骤 3 中的图像 2,2
    • To access the inner components of the device, remove the various screws. Keep them separate, and organize them by size.
    • You will need a T5 Precision Torx screw driver to remove the screws.
    • The locations of the T5x3.4mm screws are indicated in the picture.
    • The locations of the T5x4.1mm screws are indicated in the picture.
    询问修复机器人
    添加评论
  4. Nokia XL Dual SIM Disassembly, Screen Separation part 2: 步骤 4 中的图像 1,3 Nokia XL Dual SIM Disassembly, Screen Separation part 2: 步骤 4 中的图像 2,3 Nokia XL Dual SIM Disassembly, Screen Separation part 2: 步骤 4 中的图像 3,3
    • Use the plastic opening tool to gently pry the device apart.
    • There are flaps on both sides of the phone as indicated in the picture. This is what you will need to pry apart.
    • Please be cautious when opening the device. There are various connectors inside the device that must be handled with care.
    询问修复机器人
    添加评论
  5. Nokia XL Dual SIM Disassembly, System components: 步骤 5 中的图像 1,1
    • Once the device is open, take note of all the components.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
Shadeed Bilal
于09/25/14注册
231 声望
创作了4篇指南
团队
USF Tampa, Team 1-4, Brown Fall 2014 USF Tampa, Team 1-4, Brown Fall 2014 的会员
USFT-BROWN-F14S1G4
3 名成员
创作了21篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 18
总计 469
