跳转到主内容
Nokia G310 5G Charging Port Assembly Replacement
你所需要的
  1. Nokia G310 5G Charging Port Assembly Replacement, Eject the SIM card tray: 步骤 1 中的图像 1,3 Nokia G310 5G Charging Port Assembly Replacement, Eject the SIM card tray: 步骤 1 中的图像 2,3 Nokia G310 5G Charging Port Assembly Replacement, Eject the SIM card tray: 步骤 1 中的图像 3,3
    • Power down your phone and unplug any cables.
    • Insert a SIM eject tool, bit, or a straightened paper clip into the small hole on the SIM card tray on the upper left edge of the phone.
    • Press firmly to eject the tray.
  2. Nokia G310 5G Charging Port Assembly Replacement, Remove the SIM card tray: 步骤 2 中的图像 1,3 Nokia G310 5G Charging Port Assembly Replacement, Remove the SIM card tray: 步骤 2 中的图像 2,3 Nokia G310 5G Charging Port Assembly Replacement, Remove the SIM card tray: 步骤 2 中的图像 3,3
    • Remove the SIM card tray.
    • When installing either a SIM card or a microSD card, make sure they're in the correct orientation and sitting completely flush with the edges of the tray before reinserting the tray into the phone.
  3. Nokia G310 5G Charging Port Assembly Replacement, Insert an opening pick: 步骤 3 中的图像 1,3 Nokia G310 5G Charging Port Assembly Replacement, Insert an opening pick: 步骤 3 中的图像 2,3 Nokia G310 5G Charging Port Assembly Replacement, Insert an opening pick: 步骤 3 中的图像 3,3
    • The back cover is held in place by plastic clips.
    • Insert an opening pick under the small notch in the SIM card tray slot.
  4. Nokia G310 5G Charging Port Assembly Replacement, Release the plastic clips: 步骤 4 中的图像 1,3 Nokia G310 5G Charging Port Assembly Replacement, Release the plastic clips: 步骤 4 中的图像 2,3 Nokia G310 5G Charging Port Assembly Replacement, Release the plastic clips: 步骤 4 中的图像 3,3
    • Position the opening pick at a steep downward angle between the back cover and the screen assembly.
    • Slide the opening pick down the left edge of the phone to release the plastic clips.
  5. Nokia G310 5G Charging Port Assembly Replacement: 步骤 5 中的图像 1,3 Nokia G310 5G Charging Port Assembly Replacement: 步骤 5 中的图像 2,3 Nokia G310 5G Charging Port Assembly Replacement: 步骤 5 中的图像 3,3
    • Turn the opening pick around the corner and continue to slide it along the bottom edge to release the plastic clips.
  6. Nokia G310 5G Charging Port Assembly Replacement: 步骤 6 中的图像 1,3 Nokia G310 5G Charging Port Assembly Replacement: 步骤 6 中的图像 2,3 Nokia G310 5G Charging Port Assembly Replacement: 步骤 6 中的图像 3,3
    • Slide the opening pick up the right edge to continue releasing the plastic clips.
  7. Nokia G310 5G Charging Port Assembly Replacement: 步骤 7 中的图像 1,3 Nokia G310 5G Charging Port Assembly Replacement: 步骤 7 中的图像 2,3 Nokia G310 5G Charging Port Assembly Replacement: 步骤 7 中的图像 3,3
    • Slide the opening pick along the top edge to release the remaining plastic clips.
    • Don't try to fully remove the back cover just yet, as it's still connected with a cable.
  8. Nokia G310 5G Charging Port Assembly Replacement, Flip open the back cover: 步骤 8 中的图像 1,3 Nokia G310 5G Charging Port Assembly Replacement, Flip open the back cover: 步骤 8 中的图像 2,3 Nokia G310 5G Charging Port Assembly Replacement, Flip open the back cover: 步骤 8 中的图像 3,3
    • With the phone laying screen-side down, carefully lift the right edge of the back cover, opening it like a book.
    • Take care not to strain or tear the attached fingerprint reader cable during this procedure.
    • Lay the back cover next to the phone.
  9. Nokia G310 5G Charging Port Assembly Replacement, Unfasten the fingerprint reader bracket: 步骤 9 中的图像 1,1
    • Use a Phillips screwdriver to remove the 3.8 mm‑long screw securing the fingerprint reader bracket.
  10. Nokia G310 5G Charging Port Assembly Replacement, Remove the fingerprint reader bracket: 步骤 10 中的图像 1,3 Nokia G310 5G Charging Port Assembly Replacement, Remove the fingerprint reader bracket: 步骤 10 中的图像 2,3 Nokia G310 5G Charging Port Assembly Replacement, Remove the fingerprint reader bracket: 步骤 10 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Use a pair of tweezers or your fingers to remove the fingerprint reader bracket.
    • Take care not to puncture the battery with sharp tools—a punctured or creased battery may leak dangerous chemicals or cause a fire.
    • During reassembly, make sure to slide the bracket's edge back into its slot under the motherboard cover.
  11. Nokia G310 5G Charging Port Assembly Replacement, Disconnect the fingerprint reader: 步骤 11 中的图像 1,3 Nokia G310 5G Charging Port Assembly Replacement, Disconnect the fingerprint reader: 步骤 11 中的图像 2,3 Nokia G310 5G Charging Port Assembly Replacement, Disconnect the fingerprint reader: 步骤 11 中的图像 3,3
    • Use the pointed end of a spudger to disconnect the fingerprint reader by prying the connector straight up from its socket.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down on the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
    • Remove the back cover.
  12. Nokia G310 5G Charging Port Assembly Replacement, Unfasten the motherboard cover: 步骤 12 中的图像 1,1
    • A white sticker might cover one of the top screws. Pierce through it with the tip of your screwdriver or use a pair of tweezers to remove it.
    • Use a Phillips screwdriver to remove the ten 3.8 mm-long screws securing the motherboard cover.
  13. Nokia G310 5G Charging Port Assembly Replacement, Pry up the motherboard cover: 步骤 13 中的图像 1,3 Nokia G310 5G Charging Port Assembly Replacement, Pry up the motherboard cover: 步骤 13 中的图像 2,3 Nokia G310 5G Charging Port Assembly Replacement, Pry up the motherboard cover: 步骤 13 中的图像 3,3
    • The motherboard cover is further held in place by plastic clips.
    • Insert an opening pick under the right edge of the motherboard cover.
    • Twist the opening pick to release the plastic clips.
    • During reassembly, clip in the motherboard cover on the top left first.
  14. Nokia G310 5G Charging Port Assembly Replacement, Remove the motherboard cover: 步骤 14 中的图像 1,3 Nokia G310 5G Charging Port Assembly Replacement, Remove the motherboard cover: 步骤 14 中的图像 2,3 Nokia G310 5G Charging Port Assembly Replacement, Remove the motherboard cover: 步骤 14 中的图像 3,3
    • Use a pair of tweezers or your fingers to remove the motherboard cover.
  15. Nokia G310 5G Charging Port Assembly Replacement, Disconnect the battery cable: 步骤 15 中的图像 1,2 Nokia G310 5G Charging Port Assembly Replacement, Disconnect the battery cable: 步骤 15 中的图像 2,2
    • Use the flat end of a spudger to disconnect the battery cable by prying the connector straight up from its socket.
  16. Nokia G310 5G Charging Port Assembly Replacement, Unfasten the loudspeaker: 步骤 16 中的图像 1,1
  17. Nokia G310 5G Charging Port Assembly Replacement, Pry up the loudspeaker: 步骤 17 中的图像 1,3 Nokia G310 5G Charging Port Assembly Replacement, Pry up the loudspeaker: 步骤 17 中的图像 2,3 Nokia G310 5G Charging Port Assembly Replacement, Pry up the loudspeaker: 步骤 17 中的图像 3,3
    • Insert an opening pick underneath the top right edge of the loudspeaker.
    • Avoid pushing down at a sharp angle, or you risk damaging the interconnect ribbon cable underneath.
    • Twist the opening pick to release loudspeaker from the plastic clips holding it in place.
  18. Nokia G310 5G Charging Port Assembly Replacement, Remove the loudspeaker: 步骤 18 中的图像 1,2 Nokia G310 5G Charging Port Assembly Replacement, Remove the loudspeaker: 步骤 18 中的图像 2,2
    • Use a pair of tweezers or your fingers to remove the loudspeaker.
  19. Nokia G310 5G Charging Port Assembly Replacement, Disconnect the interconnect cable: 步骤 19 中的图像 1,2 Nokia G310 5G Charging Port Assembly Replacement, Disconnect the interconnect cable: 步骤 19 中的图像 2,2
    • Use the flat end of a spudger to disconnect the interconnect cable by prying the connector straight up from its socket.
  20. Nokia G310 5G Charging Port Assembly Replacement, Disconnect the antenna cables: 步骤 20 中的图像 1,3 Nokia G310 5G Charging Port Assembly Replacement, Disconnect the antenna cables: 步骤 20 中的图像 2,3 Nokia G310 5G Charging Port Assembly Replacement, Disconnect the antenna cables: 步骤 20 中的图像 3,3
    • Use a spudger to disconnect the antenna cables by prying their coaxial connectors straight up from the sockets on the board.
  21. Nokia G310 5G Charging Port Assembly Replacement, Reposition the antenna cables: 步骤 21 中的图像 1,3 Nokia G310 5G Charging Port Assembly Replacement, Reposition the antenna cables: 步骤 21 中的图像 2,3 Nokia G310 5G Charging Port Assembly Replacement, Reposition the antenna cables: 步骤 21 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Use a pair of tweezers or your fingers to grip the antenna cables near the connectors.
    • Reposition the antenna cables out of the way of the charging port assembly.
  22. Nokia G310 5G Charging Port Assembly Replacement, Pry up the charging port assembly: 步骤 22 中的图像 1,3 Nokia G310 5G Charging Port Assembly Replacement, Pry up the charging port assembly: 步骤 22 中的图像 2,3 Nokia G310 5G Charging Port Assembly Replacement, Pry up the charging port assembly: 步骤 22 中的图像 3,3
    • The charging port assembly is held in place with mild adhesive.
    • Insert the flat end of a spudger underneath the top right edge of the charging port assembly.
    • Pivot the charging port assembly up until you can grip it with your fingers.
  23. Nokia G310 5G Charging Port Assembly Replacement, Remove the charging port assembly: 步骤 23 中的图像 1,2 Nokia G310 5G Charging Port Assembly Replacement, Remove the charging port assembly: 步骤 23 中的图像 2,2
    • Use your fingers or a pair of tweezers to remove the charging port assembly.
  24. Nokia G310 5G Charging Port Assembly Replacement, Remove the rubber gaskets: 步骤 24 中的图像 1,3 Nokia G310 5G Charging Port Assembly Replacement, Remove the rubber gaskets: 步骤 24 中的图像 2,3 Nokia G310 5G Charging Port Assembly Replacement, Remove the rubber gaskets: 步骤 24 中的图像 3,3
    • Use a pair of tweezers to remove the two black U-shaped rubber gaskets from the charging port and the headphone jack.
    • Only the charging port assembly remains.
    • During reassembly, transfer the rubber gaskets to the replacement board before securing it back into the frame.
结论
另外一个人完成了本指南。
Clay Eickemeyer
于09/19/22注册
67,291 声望
创作了453篇指南
团队
iFixit iFixit 的会员
Staff
136 名成员
创作了17,420篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 11
过去 30 天: 35
总计 330
