跳转到主内容
Nokia G22 Charging Port Assembly Replacement
你所需要的
  1. Nokia G22 Charging Port Assembly Replacement, Eject the SIM card tray: 步骤 1 中的图像 1,3 Nokia G22 Charging Port Assembly Replacement, Eject the SIM card tray: 步骤 1 中的图像 2,3 Nokia G22 Charging Port Assembly Replacement, Eject the SIM card tray: 步骤 1 中的图像 3,3
    • Insert a SIM eject tool, bit, or a straightened paper clip into the small hole on the SIM card tray on the upper left edge of the phone.
    • Press firmly to eject the tray.
  2. Nokia G22 Charging Port Assembly Replacement, Remove the SIM card tray: 步骤 2 中的图像 1,3 Nokia G22 Charging Port Assembly Replacement, Remove the SIM card tray: 步骤 2 中的图像 2,3 Nokia G22 Charging Port Assembly Replacement, Remove the SIM card tray: 步骤 2 中的图像 3,3
    • Remove the SIM card tray.
    • When installing either a SIM card or a microSD card, make sure they're in the correct orientation and sitting completely flush with the edges of the tray before reinserting the tray into the phone.
  3. Nokia G22 Charging Port Assembly Replacement, Insert an opening pick: 步骤 3 中的图像 1,3 Nokia G22 Charging Port Assembly Replacement, Insert an opening pick: 步骤 3 中的图像 2,3 Nokia G22 Charging Port Assembly Replacement, Insert an opening pick: 步骤 3 中的图像 3,3
    • The back cover of the phone is held in place by plastic clips.
    • Insert an opening pick under the small notch in the SIM card tray slot.
  4. Nokia G22 Charging Port Assembly Replacement, Release the plastic clips: 步骤 4 中的图像 1,3 Nokia G22 Charging Port Assembly Replacement, Release the plastic clips: 步骤 4 中的图像 2,3 Nokia G22 Charging Port Assembly Replacement, Release the plastic clips: 步骤 4 中的图像 3,3
    • Position the opening pick at a steep downward angle between the back cover and the screen assembly.
    • Slide the opening pick down the left edge of the phone to release the plastic clips.
  5. Nokia G22 Charging Port Assembly Replacement: 步骤 5 中的图像 1,3 Nokia G22 Charging Port Assembly Replacement: 步骤 5 中的图像 2,3 Nokia G22 Charging Port Assembly Replacement: 步骤 5 中的图像 3,3
    • Turn the opening pick around the corner and continue to slide it along the bottom edge to release the plastic clips.
  6. Nokia G22 Charging Port Assembly Replacement: 步骤 6 中的图像 1,3 Nokia G22 Charging Port Assembly Replacement: 步骤 6 中的图像 2,3 Nokia G22 Charging Port Assembly Replacement: 步骤 6 中的图像 3,3
    • Slide the opening pick up the right edge to continue releasing the plastic clips.
  7. Nokia G22 Charging Port Assembly Replacement: 步骤 7 中的图像 1,3 Nokia G22 Charging Port Assembly Replacement: 步骤 7 中的图像 2,3 Nokia G22 Charging Port Assembly Replacement: 步骤 7 中的图像 3,3
    • Slide the opening pick along the top edge to release the remaining plastic clips.
    • Don't try to fully remove the back cover just yet, as it's still connected to the phone.
  8. Nokia G22 Charging Port Assembly Replacement, Flip open the back cover: 步骤 8 中的图像 1,3 Nokia G22 Charging Port Assembly Replacement, Flip open the back cover: 步骤 8 中的图像 2,3 Nokia G22 Charging Port Assembly Replacement, Flip open the back cover: 步骤 8 中的图像 3,3
    • With the phone laying screen-side down, carefully lift the right edge of the back cover, opening it like a book.
    • Take care not to strain or tear the attached fingerprint reader cable during this procedure.
    • Lay the back cover next to the phone.
  9. Nokia G22 Charging Port Assembly Replacement, Unfasten the fingerprint reader bracket: 步骤 9 中的图像 1,1
    • Use a Phillips screwdriver to remove the 3.8 mm‑long screw securing the fingerprint reader bracket.
  10. Nokia G22 Charging Port Assembly Replacement, Remove the fingerprint reader bracket: 步骤 10 中的图像 1,2 Nokia G22 Charging Port Assembly Replacement, Remove the fingerprint reader bracket: 步骤 10 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Use a pair of tweezers or your fingers to remove the fingerprint reader bracket.
    • Take care not to puncture the battery with your tool—a punctured or bent battery may leak dangerous chemicals or cause a fire.
    • During reassembly, make sure to align the fingerprint reader bracket correctly and push the small metal edge back into its recess under the motherboard cover.
  11. Nokia G22 Charging Port Assembly Replacement, Disconnect the fingerprint reader: 步骤 11 中的图像 1,3 Nokia G22 Charging Port Assembly Replacement, Disconnect the fingerprint reader: 步骤 11 中的图像 2,3 Nokia G22 Charging Port Assembly Replacement, Disconnect the fingerprint reader: 步骤 11 中的图像 3,3
    • Use the flat end of a spudger to disconnect the fingerprint reader by prying the connector straight up from its socket.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
    • Remove the back cover.
  12. Nokia G22 Charging Port Assembly Replacement, Unfasten the motherboard cover: 步骤 12 中的图像 1,1
  13. Nokia G22 Charging Port Assembly Replacement, Pry up the motherboard cover: 步骤 13 中的图像 1,3 Nokia G22 Charging Port Assembly Replacement, Pry up the motherboard cover: 步骤 13 中的图像 2,3 Nokia G22 Charging Port Assembly Replacement, Pry up the motherboard cover: 步骤 13 中的图像 3,3
    • The motherboard cover is further held in place by plastic clips.
    • Insert an opening pick under the right edge of the motherboard cover to release its plastic clips.
    • Flip the motherboard cover over the top edge of the phone.
  14. Nokia G22 Charging Port Assembly Replacement, Remove the motherboard cover: 步骤 14 中的图像 1,3 Nokia G22 Charging Port Assembly Replacement, Remove the motherboard cover: 步骤 14 中的图像 2,3 Nokia G22 Charging Port Assembly Replacement, Remove the motherboard cover: 步骤 14 中的图像 3,3
    • The motherboard cover has two short adhesive tapes wrapped around the top edge and onto the frame.
    • Pull the motherboard cover away from the frame to separate the adhesive tape and remove it.
    • During reassembly, fold the adhesive strips onto the frame after snapping the motherboard cover back in place.
  15. Nokia G22 Charging Port Assembly Replacement, Disconnect the battery cable: 步骤 15 中的图像 1,2 Nokia G22 Charging Port Assembly Replacement, Disconnect the battery cable: 步骤 15 中的图像 2,2
    • Use the flat end of a spudger to disconnect the battery cable by prying the connector straight up from its socket.
  16. Nokia G22 Charging Port Assembly Replacement, Unfasten the loudspeaker: 步骤 16 中的图像 1,1
  17. Nokia G22 Charging Port Assembly Replacement, Pry up the loudspeaker: 步骤 17 中的图像 1,2 Nokia G22 Charging Port Assembly Replacement, Pry up the loudspeaker: 步骤 17 中的图像 2,2
    • Insert an opening pick underneath the right edge of the loudspeaker.
    • Twist the opening pick to release loudspeaker from the plastic clips holding it in place.
  18. Nokia G22 Charging Port Assembly Replacement, Remove the loudspeaker: 步骤 18 中的图像 1,1
    • Use your fingers or a pair of tweezers to remove the loudspeaker.
  19. Nokia G22 Charging Port Assembly Replacement, Disconnect the display cable: 步骤 19 中的图像 1,2 Nokia G22 Charging Port Assembly Replacement, Disconnect the display cable: 步骤 19 中的图像 2,2
    • Use the flat end of a spudger to disconnect the display cable by prying the connector straight up from its socket.
  20. Nokia G22 Charging Port Assembly Replacement, Disconnect the antenna cable: 步骤 20 中的图像 1,2 Nokia G22 Charging Port Assembly Replacement, Disconnect the antenna cable: 步骤 20 中的图像 2,2
    • Use the pointed end of a spudger to disconnect the antenna cable by prying the connector straight up from its socket on the charging port assembly.
  21. Nokia G22 Charging Port Assembly Replacement, Unfasten the charging port assembly: 步骤 21 中的图像 1,1
    • Use a Phillips screwdriver to remove the 2.8 mm‑long screw securing the charging port assembly.
  22. Nokia G22 Charging Port Assembly Replacement, Pry up the charging port assembly: 步骤 22 中的图像 1,2 Nokia G22 Charging Port Assembly Replacement, Pry up the charging port assembly: 步骤 22 中的图像 2,2
    • Insert the flat end of a spudger underneath the top edge of the charging port assembly.
    • Pry up the charging port assembly by twisting the spudger until you can grip it with your fingers.
  23. Nokia G22 Charging Port Assembly Replacement, Remove the charging port assembly: 步骤 23 中的图像 1,1
    • Remove the charging port assembly.
  24. Nokia G22 Charging Port Assembly Replacement, Remove the rubber gaskets: 步骤 24 中的图像 1,3 Nokia G22 Charging Port Assembly Replacement, Remove the rubber gaskets: 步骤 24 中的图像 2,3 Nokia G22 Charging Port Assembly Replacement, Remove the rubber gaskets: 步骤 24 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Use a pair of tweezers to remove the black rubber gaskets from the charging port and the headphone jack.
    • During reassembly, transfer the rubber gaskets to your replacement part before securing it to the frame.
    • Only the charging port assembly remains.
结论
3等其他人完成本指南。
Manuel Haeussermann
于07/13/22注册
15,619 声望
创作了71篇指南
团队
iFixit iFixit 的会员
Staff
136 名成员
创作了17,433篇指南
一条评论
so helpful ,i really appreciate the guide
mekita boy - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 18
过去 30 天: 79
总计 2,644
