跳转到主内容
加入维修社区 - 创建账户
Nokia 6010 screen and speaker replacement
你所需要的
  1. Nokia 6010 screen and speaker replacement, Battery: 步骤 1 中的图像 1,3 Nokia 6010 screen and speaker replacement, Battery: 步骤 1 中的图像 2,3 Nokia 6010 screen and speaker replacement, Battery: 步骤 1 中的图像 3,3
    • Press the small tab on the bottom of the back of the phone.
    • Push the back case upward towards the power button. The back case will then pop off.
    • It requires some force, so be careful.
    询问修复机器人
    添加评论
  2. Nokia 6010 screen and speaker replacement: 步骤 2 中的图像 1,2 Nokia 6010 screen and speaker replacement: 步骤 2 中的图像 2,2
    • Lift the battery near the bottom and pry up.
    询问修复机器人
    添加评论
  3. Nokia 6010 screen and speaker replacement, SIM Card: 步骤 3 中的图像 1,1
    • With one hand, press the ridged tab near the visible side of the SIM card.
    • Slide the card out with your other hand.
    添加评论
  4. Nokia 6010 screen and speaker replacement, Keypad: 步骤 4 中的图像 1,2 Nokia 6010 screen and speaker replacement, Keypad: 步骤 4 中的图像 2,2
    • Grip the phone on either the sides, the top, or the bottom.
    • Pull the front case away from the rest of the phone.
    • There are no special tabs to keep it in place so it should wiggle free easily.
    询问修复机器人
    添加评论
  5. Nokia 6010 screen and speaker replacement: 步骤 5 中的图像 1,1
    • Lift the keypad away from the body of the phone.
    • The keypad is the rubber-backed piece with the number keys.
    询问修复机器人
    添加评论
  6. Nokia 6010 screen and speaker replacement, LCD Screen and Speaker: 步骤 6 中的图像 1,2 Nokia 6010 screen and speaker replacement, LCD Screen and Speaker: 步骤 6 中的图像 2,2
    • Remove the six screws around the front of the phone body with a T6 screwdriver.
    询问修复机器人
    添加评论
  7. Nokia 6010 screen and speaker replacement: 步骤 7 中的图像 1,3 Nokia 6010 screen and speaker replacement: 步骤 7 中的图像 2,3 Nokia 6010 screen and speaker replacement: 步骤 7 中的图像 3,3
    • Insert your finger underneath the speaker piece and pry away from the phone body.
    • The plastic layer containing the LCD screen and speaker takes some force to remove.
    • There are 4 plastic tabs which keep it in place, but they are hard to press. Be careful and go tab by tab or use a spudger if you are nervous about using too much force.
    • The LCD and the speaker are attached to the same piece and must be replaced together.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
2等其他人完成本指南。
团队
Cal Poly, Team 14-45, Regan Winter 2010 Cal Poly, Team 14-45, Regan Winter 2010 的会员
CPSU-REGAN-W10S14G45
5 名成员
创作了32篇指南
1指南评论
Greatly appreciated !!!
Tobi Hunt - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 39
总计 4,749
