跳转到主内容
加入维修社区 - 创建账户
Nokia 2115i Motherboard Replacement
你所需要的
    1. Nokia 2115i Motherboard Replacement, Nokia 2115i Battery: 步骤 1 中的图像 1,3 Nokia 2115i Motherboard Replacement, Nokia 2115i Battery: 步骤 1 中的图像 2,3 Nokia 2115i Motherboard Replacement, Nokia 2115i Battery: 步骤 1 中的图像 3,3
      • To prevent shock, press down on the power button located on the top of the phone until the phone shuts off.
      • Press down on the small gray button located on the back of the phone.
      • Slide the back plate down and off.
      询问修复机器人
      添加评论
    2. Nokia 2115i Motherboard Replacement: 步骤 2 中的图像 1,2 Nokia 2115i Motherboard Replacement: 步骤 2 中的图像 2,2
      • To remove the battery, begin by holding the phone sideways.
      • Then, insert your thumb in the groove below the battery and push the battery up and out.
      询问修复机器人
      添加评论
    1. Nokia 2115i Motherboard Replacement, Faceplate: 步骤 3 中的图像 1,3 Nokia 2115i Motherboard Replacement, Faceplate: 步骤 3 中的图像 2,3 Nokia 2115i Motherboard Replacement, Faceplate: 步骤 3 中的图像 3,3
      • Locate the spudger. A photo of the correct spudger is provided to the left.
      • Turn the front of the phone to face you. Find the two small square holes on the bottom left and right sides of the faceplate.
      • Insert the spudger into each square hole and push up to detach the face plate.
      询问修复机器人
      添加评论
    1. Nokia 2115i Motherboard Replacement, Removing the Keypad: 步骤 4 中的图像 1,2 Nokia 2115i Motherboard Replacement, Removing the Keypad: 步骤 4 中的图像 2,2
      • Note: The keypad will be loose and may fall off during this step.
      • Pull the face plate up and off of the phone.
      • To remove the keypad, simply lift it off the phone.
      询问修复机器人
      添加评论
    1. Nokia 2115i Motherboard Replacement, Removing the Motherboard: 步骤 5 中的图像 1,2 Nokia 2115i Motherboard Replacement, Removing the Motherboard: 步骤 5 中的图像 2,2
      在这个步骤中使用的工具:
      • Locate the 6 screws on the metallic sheet that previously held the keypad. (This sheet, shown in the pictures, is the top side of the motherboard).
      • Note: 2 of the screws are on the bottom corners, 2 are on the right and left edges of the phone below the screen, and 2 are on the very top corners of the phone, above the screen.
      • Warning: The middle two screws are attached to the base of the phone with two black plastic rings. Use tweezers to remove the screws carefully to avoid breaking the plastic rings
      • Use a size T6 Torx screwdriver to remove each of these 6 screws.
      询问修复机器人
      添加评论
    2. Nokia 2115i Motherboard Replacement: 步骤 6 中的图像 1,3 Nokia 2115i Motherboard Replacement: 步骤 6 中的图像 2,3 Nokia 2115i Motherboard Replacement: 步骤 6 中的图像 3,3
      • To remove the motherboard, lift it up and off the phone.
      • Note: The screen will still be attached to the motherboard.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
Shane
于09/30/10注册
80 声望
创作了6篇指南
团队
Cal Poly, Team 14-38, Forte Fall 2010 Cal Poly, Team 14-38, Forte Fall 2010 的会员
CPSU-FORTE-F10S14G38
5 名成员
创作了42篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 25
总计 3,368
