跳转到主内容
加入维修社区 - 创建账户
Nokia C7 - 00 Touchscreen Replacement
  1. Nokia  C7 - 00 Touchscreen  Replacement, Touchscreen and LCD: 步骤 1 中的图像 1,3 Nokia  C7 - 00 Touchscreen  Replacement, Touchscreen and LCD: 步骤 1 中的图像 2,3 Nokia  C7 - 00 Touchscreen  Replacement, Touchscreen and LCD: 步骤 1 中的图像 3,3
    • With a thin tool insert it in the cover at the bottom and pry up to release it
    询问修复机器人
    添加评论
  2. Nokia  C7 - 00 Touchscreen  Replacement: 步骤 2 中的图像 1,2 Nokia  C7 - 00 Touchscreen  Replacement: 步骤 2 中的图像 2,2
    • Pry up the two points indicated by the arrows to release the keyboard
    询问修复机器人
    添加评论
  3. Nokia  C7 - 00 Touchscreen  Replacement: 步骤 3 中的图像 1,2 Nokia  C7 - 00 Touchscreen  Replacement: 步骤 3 中的图像 2,2
    • Remove battery and battery cover
    询问修复机器人
    添加评论
  4. Nokia  C7 - 00 Touchscreen  Replacement: 步骤 4 中的图像 1,2 Nokia  C7 - 00 Touchscreen  Replacement: 步骤 4 中的图像 2,2
    • Unscrew the 2 rear screws
    • Unscrew the 2 front screws
    询问修复机器人
    添加评论
  5. Nokia  C7 - 00 Touchscreen  Replacement: 步骤 5 中的图像 1,3 Nokia  C7 - 00 Touchscreen  Replacement: 步骤 5 中的图像 2,3 Nokia  C7 - 00 Touchscreen  Replacement: 步骤 5 中的图像 3,3
    • Gently lift the front glass and slide it slightly in the direction of the arrow so you can free it
    询问修复机器人
    添加评论
  6. Nokia  C7 - 00 Touchscreen  Replacement: 步骤 6 中的图像 1,3 Nokia  C7 - 00 Touchscreen  Replacement: 步骤 6 中的图像 2,3 Nokia  C7 - 00 Touchscreen  Replacement: 步骤 6 中的图像 3,3
    • if the display needs to be replaced and then you have no problems if it is broken in the door, proceed with a heat source and a thin tool to be able to break it from underneath
    • If the display is as good as in my case to avoid the risk of breaking it, unscrew the two red arrow screws
    • Gradually unscrew the purple arrow screw so that you do not lose too much on the back of the display to avoid breaking it, at the same time lift it from the keyboard area and gradually unscrew Dino to the complete lifting of the display and its housing doing Leva also laterally on the releases
    询问修复机器人
    添加评论
  7. Nokia  C7 - 00 Touchscreen  Replacement: 步骤 7 中的图像 1,2 Nokia  C7 - 00 Touchscreen  Replacement: 步骤 7 中的图像 2,2
    • Lift up display assembly.
    询问修复机器人
    添加评论
  8. Nokia  C7 - 00 Touchscreen  Replacement: 步骤 8 中的图像 1,3 Nokia  C7 - 00 Touchscreen  Replacement: 步骤 8 中的图像 2,3 Nokia  C7 - 00 Touchscreen  Replacement: 步骤 8 中的图像 3,3
    • Disconnect touch screen connector
    • Disconnect display connector
    询问修复机器人
    添加评论
结论
To reassemble the device, follow these instructions in reverse order.
取消:我没有完成这个指南。
5等其他人完成本指南。
由衷感谢以下译者:
it en
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
Smilzo
于11/09/13注册
12,320 声望
创作了39篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 41
总计 2,988
