跳转到主内容
加入维修社区 - 创建账户
Nintendo Wii U Pro Controller ABXY Buttons Replacement
你所需要的
  1. Nintendo Wii U Pro Controller ABXY Buttons Replacement, Battery: 步骤 1 中的图像 1,1
    • Turn the controller over to reveal the battery cover.
    • Use the J000 screwdriver to remove the screw that secures the battery cover.
    询问修复机器人
    添加评论
  2. Nintendo Wii U Pro Controller ABXY Buttons Replacement: 步骤 2 中的图像 1,2 Nintendo Wii U Pro Controller ABXY Buttons Replacement: 步骤 2 中的图像 2,2
    • Remove the battery from the controller by inserting the plastic spudger into the small gap on the bottom right of the battery.
    • Use the spudger as a lever to pry up and remove the battery from the compartment.
    询问修复机器人
    添加评论
  3. Nintendo Wii U Pro Controller ABXY Buttons Replacement, Joystick Cover: 步骤 3 中的图像 1,1
    • Remove the eight 5.5 mm Y0 screws.
    添加评论
  4. Nintendo Wii U Pro Controller ABXY Buttons Replacement: 步骤 4 中的图像 1,2 Nintendo Wii U Pro Controller ABXY Buttons Replacement: 步骤 4 中的图像 2,2
    • Now that you have removed all of the screws, carefully separate and remove the bottom half of the controller shell from the top half.
    • If you feel any resistance when pulling the shells apart, use a spudger to separate the left and right trigger contact assemblies from the bottom shell.
    询问修复机器人
    添加评论
  5. Nintendo Wii U Pro Controller ABXY Buttons Replacement: 步骤 5 中的图像 1,1
    • Move the right trigger and sensor out of the way.
    • Remove the 4 mm JIS #0 screw.
    询问修复机器人
    添加评论
  6. Nintendo Wii U Pro Controller ABXY Buttons Replacement: 步骤 6 中的图像 1,1
    • Move the left trigger and sensor out of the way.
    询问修复机器人
    添加评论
  7. Nintendo Wii U Pro Controller ABXY Buttons Replacement: 步骤 7 中的图像 1,1
    • Remove the joysticks and motherboard from the controller’s shell.
    询问修复机器人
    添加评论
  8. Nintendo Wii U Pro Controller ABXY Buttons Replacement: 步骤 8 中的图像 1,1
    • Carefully pull the rubber thumbsticks off of the electronic bearings to remove the joysticks.
    询问修复机器人
    添加评论
  9. Nintendo Wii U Pro Controller ABXY Buttons Replacement, ABXY Buttons: 步骤 9 中的图像 1,3 Nintendo Wii U Pro Controller ABXY Buttons Replacement, ABXY Buttons: 步骤 9 中的图像 2,3 Nintendo Wii U Pro Controller ABXY Buttons Replacement, ABXY Buttons: 步骤 9 中的图像 3,3
    • Now that the joysticks are removed, locate the screws on the left and right side of the controller (highlighted in the photos) and use the J0 bit to remove these 4 mm screws. This will allow you to pull out the controller board
    询问修复机器人
    添加评论
  10. Nintendo Wii U Pro Controller ABXY Buttons Replacement: 步骤 10 中的图像 1,2 Nintendo Wii U Pro Controller ABXY Buttons Replacement: 步骤 10 中的图像 2,2
    • Once these two screws have been removed, you may go ahead and remove the board from the controller housing. Now, direct your attention to the front panel of the controller. Remove the buttons and wipe them down completely with rubbing alcohol and a q-tip. Set them aside to dry for several minutes.
    询问修复机器人
    添加评论
  11. Nintendo Wii U Pro Controller ABXY Buttons Replacement: 步骤 11 中的图像 1,2 Nintendo Wii U Pro Controller ABXY Buttons Replacement: 步骤 11 中的图像 2,2
    • Remove the rubber covers (circled in the photo) from the ABXY sensors from the control board that was removed from the housing.
    询问修复机器人
    添加评论
  12. Nintendo Wii U Pro Controller ABXY Buttons Replacement: 步骤 12 中的图像 1,1
    • Wipe down the rubber cover pad completely with rubbing alcohol and a q-tip. Use compressed air to clean off the contact sensors (highlighted by the red circle).
    询问修复机器人
    添加评论
结论
To reassemble your device, carefully follow these instructions in reverse order.
取消:我没有完成这个指南。
5等其他人完成本指南。
Will Grabb
于09/17/15注册
228 声望
撰写一个指南
团队
IUPUI, Team 2-2, Harley Fall 2015 IUPUI, Team 2-2, Harley Fall 2015 的会员
IUPUI-HARLEY-F15S2G2
4 名成员
创作了15篇指南
1指南评论
Thanks so much! I spilt milk on my controller and got the buttons all gummed up but this guide helped me clean them up, including dust and the gunk inside of it, you saved me a ton of money!
Patrick Caudill - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 16
过去 30 天: 96
总计 5,892
