跳转到主内容
加入维修社区 - 创建账户
Nintendo Wii Remote Speaker Replacement
你所需要的
  1. Nintendo Wii Remote Speaker Replacement, Front Cover Plate and Batteries: 步骤 1 中的图像 1,2 Nintendo Wii Remote Speaker Replacement, Front Cover Plate and Batteries: 步骤 1 中的图像 2,2
    • Flip the Wii Remote over so the battery cover faces you.
    • Push up on the bottom tab.
    • Remove the battery cover.
    添加评论
  2. Nintendo Wii Remote Speaker Replacement: 步骤 2 中的图像 1,1
    • Remove the first battery by pressing down on the positive end and pulling the battery out.
    • Remove the second battery by pushing up on the positive end and pulling the battery out.
    询问修复机器人
    添加评论
  3. Nintendo Wii Remote Speaker Replacement: 步骤 3 中的图像 1,1
    • Using a tri-point Y1 Screwdriver, remove the two center 7mm screws by turning them counterclockwise.
    • Repeat with the two bottom screws.
    询问修复机器人
    添加评论
  4. Nintendo Wii Remote Speaker Replacement: 步骤 4 中的图像 1,2 Nintendo Wii Remote Speaker Replacement: 步骤 4 中的图像 2,2
    • With the flat end of a spudger, gently apply pressure to the tabs located on left side of the controller.
    • These tabs are breakable. However, if the tabs are broken the controller will still function.
    • Open the front plate like a book.
    • Small parts may fall out as you open the front plate.
    添加评论
  5. Nintendo Wii Remote Speaker Replacement, Speaker: 步骤 5 中的图像 1,3 Nintendo Wii Remote Speaker Replacement, Speaker: 步骤 5 中的图像 2,3 Nintendo Wii Remote Speaker Replacement, Speaker: 步骤 5 中的图像 3,3
    • Place the plastic opening tool between the edge of the speaker and the wii remote.
    • Gently lift the speaker out of the body of the Wii remote.
    添加评论
结论
取消:我没有完成这个指南。
2等其他人完成本指南。
Emily
于04/14/13注册
2,015 声望
创作了6篇指南
团队
Cal Poly, Team 3-44, Amido Spring 2013 Cal Poly, Team 3-44, Amido Spring 2013 的会员
CPSU-AMIDO-S13S3G44
4 名成员
创作了29篇指南
2指南评论
Thank you, u help me to fix it.
joon lew - 回复 分享
That's cool and all, but what speaker am I supposed to buy?
Shadow - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 17
过去 30 天: 155
总计 9,618
