跳转到主内容
加入维修社区 - 创建账户
Nintendo Wii Remote Sensor Screen Replacement
你所需要的
    1. Nintendo Wii Remote Sensor Screen Replacement, Front Cover Plate and Batteries: 步骤 1 中的图像 1,2 Nintendo Wii Remote Sensor Screen Replacement, Front Cover Plate and Batteries: 步骤 1 中的图像 2,2
      • Flip the Wii Remote over so the battery cover faces you.
      • Push up on the bottom tab.
      • Remove the battery cover.
      添加评论
    2. Nintendo Wii Remote Sensor Screen Replacement: 步骤 2 中的图像 1,1
      • Remove the first battery by pressing down on the positive end and pulling the battery out.
      • Remove the second battery by pushing up on the positive end and pulling the battery out.
      询问修复机器人
      添加评论
    3. Nintendo Wii Remote Sensor Screen Replacement: 步骤 3 中的图像 1,1
      • Using a tri-point Y1 Screwdriver, remove the two center 7mm screws by turning them counterclockwise.
      • Repeat with the two bottom screws.
      询问修复机器人
      添加评论
    4. Nintendo Wii Remote Sensor Screen Replacement: 步骤 4 中的图像 1,2 Nintendo Wii Remote Sensor Screen Replacement: 步骤 4 中的图像 2,2
      • With the flat end of a spudger, gently apply pressure to the tabs located on left side of the controller.
      • These tabs are breakable. However, if the tabs are broken the controller will still function.
      • Open the front plate like a book.
      • Small parts may fall out as you open the front plate.
      添加评论
    1. Nintendo Wii Remote Sensor Screen Replacement, Sensor Screen: 步骤 5 中的图像 1,3 Nintendo Wii Remote Sensor Screen Replacement, Sensor Screen: 步骤 5 中的图像 2,3 Nintendo Wii Remote Sensor Screen Replacement, Sensor Screen: 步骤 5 中的图像 3,3
      • Tilt the remote, without the front cover plate, upward so the handle strap is at the bottom and the black screen is facing you.
      • Grip the outward edge of the screen with your fingers.
      • Gently, pull the screen straight outward from its housing. The screen will slide directly out.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
16等其他人完成本指南。
Emily
于04/14/13注册
2,030 声望
创作了6篇指南
团队
Cal Poly, Team 3-44, Amido Spring 2013 Cal Poly, Team 3-44, Amido Spring 2013 的会员
CPSU-AMIDO-S13S3G44
4 名成员
创作了72篇指南
2指南评论
Where can the screen be purchased??
cutsiepie6480 - 回复 分享
how is this moderate difficulty
Sqwerks - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 23
过去 7 天: 123
过去 30 天: 488
总计 28,068
