跳转到主内容
Nintendo Switch OLED Model Shield Plate Replacement
你所需要的
  1. Nintendo Switch OLED Model Shield Plate Replacement, Release the Joy Con controller locking tabs: 步骤 1 中的图像 1,3 Nintendo Switch OLED Model Shield Plate Replacement, Release the Joy Con controller locking tabs: 步骤 1 中的图像 2,3 Nintendo Switch OLED Model Shield Plate Replacement, Release the Joy Con controller locking tabs: 步骤 1 中的图像 3,3
    • Before you begin this repair, make sure the device is completely powered off.
    • Press and hold down the small round button on the back of the Joy Con controller.
    • While you hold down the button, slide the controller upward.
  2. Nintendo Switch OLED Model Shield Plate Replacement, Remove the Joy Con controllers: 步骤 2 中的图像 1,3 Nintendo Switch OLED Model Shield Plate Replacement, Remove the Joy Con controllers: 步骤 2 中的图像 2,3 Nintendo Switch OLED Model Shield Plate Replacement, Remove the Joy Con controllers: 步骤 2 中的图像 3,3
    • Continue sliding the Joy Con upward until it's completely removed from the console.
    • Repeat this same process for the other Joy Con.
  3. Nintendo Switch OLED Model Shield Plate Replacement, Remove the top screw: 步骤 3 中的图像 1,2 Nintendo Switch OLED Model Shield Plate Replacement, Remove the top screw: 步骤 3 中的图像 2,2
    • Use a Phillips driver, or a JIS driver, to remove the 2 mm-long screw securing the top of the rear case to the frame.
    • To prevent these tight screws from stripping, apply firm downward force, work slowly, and try another JIS or Phillips driver if the screws won't come out.
  4. Nintendo Switch OLED Model Shield Plate Replacement, Remove the bottom screws: 步骤 4 中的图像 1,2 Nintendo Switch OLED Model Shield Plate Replacement, Remove the bottom screws: 步骤 4 中的图像 2,2
    • Use a Phillips driver to remove the two 2 mm-long screws securing the bottom of the rear case to the frame.
  5. Nintendo Switch OLED Model Shield Plate Replacement, Remove the right screw: 步骤 5 中的图像 1,2 Nintendo Switch OLED Model Shield Plate Replacement, Remove the right screw: 步骤 5 中的图像 2,2
    • Use a Phillips driver to remove the 3.8 mm screw securing the right Joy-Con sensor rail to the rear case.
    • To prevent these tight screws from stripping, apply firm downward force, work slowly and try another JIS 000 or PH 000 driver if the screws won't come out.
  6. Nintendo Switch OLED Model Shield Plate Replacement, Remove the left screw: 步骤 6 中的图像 1,2 Nintendo Switch OLED Model Shield Plate Replacement, Remove the left screw: 步骤 6 中的图像 2,2
    • Use a Phillips driver to remove the 3.8 mm screw securing the left Joy-Con sensor rail to the rear case.
  7. Nintendo Switch OLED Model Shield Plate Replacement, Open the kickstand: 步骤 7 中的图像 1,2 Nintendo Switch OLED Model Shield Plate Replacement, Open the kickstand: 步骤 7 中的图像 2,2
    • Use your finger to flip up the kickstand on the back of the device.
    • If there's a microSD card in the microSD card slot, remove it now before you continue to the next step.
  8. Nintendo Switch OLED Model Shield Plate Replacement, Remove the back-side screws: 步骤 8 中的图像 1,2 Nintendo Switch OLED Model Shield Plate Replacement, Remove the back-side screws: 步骤 8 中的图像 2,2
    • Use a Y00 screwdriver to remove the two 4.3 mm screws securing the rear case to the frame.
  9. Nintendo Switch OLED Model Shield Plate Replacement, Remove the rear case: 步骤 9 中的图像 1,3 Nintendo Switch OLED Model Shield Plate Replacement, Remove the rear case: 步骤 9 中的图像 2,3 Nintendo Switch OLED Model Shield Plate Replacement, Remove the rear case: 步骤 9 中的图像 3,3
    • Lift the rear case up from the top of the device and remove it.
    • If you're having trouble removing the case, use an opening pick to pry up the plastic clips.
  10. Nintendo Switch OLED Model Shield Plate Replacement, Remove the shield plate's tape: 步骤 10 中的图像 1,2 Nintendo Switch OLED Model Shield Plate Replacement, Remove the shield plate's tape: 步骤 10 中的图像 2,2
    • Use the flat end of a spudger to separate a corner of the tape from the shield plate.
  11. Nintendo Switch OLED Model Shield Plate Replacement: 步骤 11 中的图像 1,3 Nintendo Switch OLED Model Shield Plate Replacement: 步骤 11 中的图像 2,3 Nintendo Switch OLED Model Shield Plate Replacement: 步骤 11 中的图像 3,3
    在这个步骤中使用的工具:
    • Use tweezers, or your fingers, to peel back and remove the tape.
    • Store the tape in a clean space for reinstallation.
  12. Nintendo Switch OLED Model Shield Plate Replacement, Disconnect the primary Wi-Fi antenna: 步骤 12 中的图像 1,2 Nintendo Switch OLED Model Shield Plate Replacement, Disconnect the primary Wi-Fi antenna: 步骤 12 中的图像 2,2
    • Use tweezers, or your fingers, to pull up and disconnect the primary Wi-Fi antenna's coaxial cable.
    • During reassembly, these can be tricky to reconnect. One at a time, hold each connector in place over its socket and press down with the flat end of a spudger. The connector should snap into place.
  13. Nintendo Switch OLED Model Shield Plate Replacement, Reroute the primary antenna's coaxial cable: 步骤 13 中的图像 1,3 Nintendo Switch OLED Model Shield Plate Replacement, Reroute the primary antenna's coaxial cable: 步骤 13 中的图像 2,3 Nintendo Switch OLED Model Shield Plate Replacement, Reroute the primary antenna's coaxial cable: 步骤 13 中的图像 3,3
    • Use tweezers, or your fingers, to reroute the primary antenna's coaxial cable out of its slots in the shield plate.
  14. Nintendo Switch OLED Model Shield Plate Replacement, Unfasten the primary Wi-Fi antenna: 步骤 14 中的图像 1,2 Nintendo Switch OLED Model Shield Plate Replacement, Unfasten the primary Wi-Fi antenna: 步骤 14 中的图像 2,2
    • Use a Phillips driver to remove the two 4.4 mm screws securing the primary Wi-Fi antenna to the shield plate.
  15. Nintendo Switch OLED Model Shield Plate Replacement, Remove the primary Wi-Fi antenna: 步骤 15 中的图像 1,3 Nintendo Switch OLED Model Shield Plate Replacement, Remove the primary Wi-Fi antenna: 步骤 15 中的图像 2,3 Nintendo Switch OLED Model Shield Plate Replacement, Remove the primary Wi-Fi antenna: 步骤 15 中的图像 3,3
    • Insert an opening pick between the primary Wi-Fi antenna and the shield plate.
    • Pry up with the pick to separate the primary Wi-Fi antenna from the shield plate.
  16. Nintendo Switch OLED Model Shield Plate Replacement: 步骤 16 中的图像 1,2 Nintendo Switch OLED Model Shield Plate Replacement: 步骤 16 中的图像 2,2
    • Remove the primary Wi-Fi antenna.
  17. Nintendo Switch OLED Model Shield Plate Replacement, Disconnect the secondary Wi-Fi antenna: 步骤 17 中的图像 1,2 Nintendo Switch OLED Model Shield Plate Replacement, Disconnect the secondary Wi-Fi antenna: 步骤 17 中的图像 2,2
    • Use tweezers, or your fingers, to pull up and disconnect the secondary Wi-Fi antenna's coaxial cable.
  18. Nintendo Switch OLED Model Shield Plate Replacement, Reroute the secondary Wi-Fi antenna's coaxial cable: 步骤 18 中的图像 1,2 Nintendo Switch OLED Model Shield Plate Replacement, Reroute the secondary Wi-Fi antenna's coaxial cable: 步骤 18 中的图像 2,2
    • Use the point of a spudger to reroute the secondary Wi-Fi antenna's coaxial cable from its slot in the frame.
  19. Nintendo Switch OLED Model Shield Plate Replacement, Unfasten the secondary Wi-Fi antenna: 步骤 19 中的图像 1,2 Nintendo Switch OLED Model Shield Plate Replacement, Unfasten the secondary Wi-Fi antenna: 步骤 19 中的图像 2,2
    • Use a Phillips driver to remove the 4.4 mm screw securing the secondary Wi-Fi antenna to the shield plate.
  20. Nintendo Switch OLED Model Shield Plate Replacement, Remove the secondary Wi-Fi antenna: 步骤 20 中的图像 1,3 Nintendo Switch OLED Model Shield Plate Replacement, Remove the secondary Wi-Fi antenna: 步骤 20 中的图像 2,3 Nintendo Switch OLED Model Shield Plate Replacement, Remove the secondary Wi-Fi antenna: 步骤 20 中的图像 3,3
    • Insert an opening pick between the secondary Wi-Fi antenna and the shield plate.
    • Pry up with the pick to separate the secondary Wi-Fi antenna from the shield plate.
    • Don't attempt to completely remove the antenna yet, as its coaxial cable is still routed through the frame.
  21. Nintendo Switch OLED Model Shield Plate Replacement: 步骤 21 中的图像 1,3 Nintendo Switch OLED Model Shield Plate Replacement: 步骤 21 中的图像 2,3 Nintendo Switch OLED Model Shield Plate Replacement: 步骤 21 中的图像 3,3
    • Use the point of a spudger to reroute the secondary Wi-Fi antenna's coaxial cable out of its slot in the frame.
    • Remove the secondary Wi-Fi antenna.
  22. Nintendo Switch OLED Model Shield Plate Replacement, Unfasten the shield plate: 步骤 22 中的图像 1,2 Nintendo Switch OLED Model Shield Plate Replacement, Unfasten the shield plate: 步骤 22 中的图像 2,2
    • Use a Phillips driver to remove the six 4.4 mm screws securing the shield plate to the frame.
  23. Nintendo Switch OLED Model Shield Plate Replacement: 步骤 23 中的图像 1,2 Nintendo Switch OLED Model Shield Plate Replacement: 步骤 23 中的图像 2,2
    在这个步骤中使用的工具:
    iFixit Thermal Putty
    $9.95
    • Use your fingers to lift the top of the shield plate up and away from the frame.
    • You may feel a bit of resistance. This is normal, since the shield plate is slightly bonded to the heat sink with thermal paste.
    • Remove the shield plate.
    • A thick pink thermal compound bridges the gap between the shield plate and the copper heat sink underneath. Whenever the shield plate is removed, refer to our thermal paste guide to remove the old thermal compound and replace it with an appropriate compound, such as thermal putty or K5 Pro, during reassembly.
结论
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Nintendo Switch OLED Answers community for help.
另外一个人完成了本指南。
Alex Diaz-Kokaisl
于01/16/22注册
213,742 声望
创作了1,041篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了23,729篇指南
3指南评论
My question is, where do I get replacement screws? Are the shield screws the same size as the regular switch?
Ren Aokawa - 回复
Hi Ren.
Unfortunately, we don't sell the screws alongside the replacement shield. The regular Switch has different screws as well, but you might find some on eBay. I'm not sure how effective Nintendo's customer service is here, but you could give it a shot to find out the type of screws.
Alex Diaz-Kokaisl -
Where do I even by the oled heat plate from I keep finding normal switch or this %#*@ tutorial
Irritating llama - 回复
添加评论
浏览统计数据:
过去 24 小时: 10
过去 7 天: 44
过去 30 天: 193
总计 5,795
