跳转到主内容
Nintendo Switch OLED Model Dock USB-C Assembly Replacement
你所需要的
  1. Nintendo Switch OLED Model Dock USB-C Assembly Replacement, Remove the rear cover: 步骤 1 中的图像 1,3 Nintendo Switch OLED Model Dock USB-C Assembly Replacement, Remove the rear cover: 步骤 1 中的图像 2,3 Nintendo Switch OLED Model Dock USB-C Assembly Replacement, Remove the rear cover: 步骤 1 中的图像 3,3
    • Use your fingers to pull the rear cover away from the frame and release its plastic clips.
    • Remove the rear cover.
  2. Nintendo Switch OLED Model Dock USB-C Assembly Replacement, Unfasten the baseplate: 步骤 2 中的图像 1,2 Nintendo Switch OLED Model Dock USB-C Assembly Replacement, Unfasten the baseplate: 步骤 2 中的图像 2,2
    • Use a Y0 screwdriver to unfasten the 7.5 mm-long screw securing the baseplate to the frame.
  3. Nintendo Switch OLED Model Dock USB-C Assembly Replacement, Remove the screw cover: 步骤 3 中的图像 1,3 Nintendo Switch OLED Model Dock USB-C Assembly Replacement, Remove the screw cover: 步骤 3 中的图像 2,3 Nintendo Switch OLED Model Dock USB-C Assembly Replacement, Remove the screw cover: 步骤 3 中的图像 3,3
    • Insert an opening tool between the frame and the plastic screw cover at the bottom-left corner.
    • Pry up with the opening tool to separate the screw cover from the frame.
    • Remove the screw cover.
  4. Nintendo Switch OLED Model Dock USB-C Assembly Replacement, Unfasten the midframe: 步骤 4 中的图像 1,2 Nintendo Switch OLED Model Dock USB-C Assembly Replacement, Unfasten the midframe: 步骤 4 中的图像 2,2
    • Use a Y0 screwdriver to remove the seven screws securing the midframe to the frame:
    • Four 3.9 mm screws
    • Three 7.5 mm screws
    • One 3.9 mm screw
  5. Nintendo Switch OLED Model Dock USB-C Assembly Replacement, Remove the midframe: 步骤 5 中的图像 1,3 Nintendo Switch OLED Model Dock USB-C Assembly Replacement, Remove the midframe: 步骤 5 中的图像 2,3 Nintendo Switch OLED Model Dock USB-C Assembly Replacement, Remove the midframe: 步骤 5 中的图像 3,3
    • Use your fingers to remove the midframe from the frame.
  6. Nintendo Switch OLED Model Dock USB-C Assembly Replacement, Remove the baseplate: 步骤 6 中的图像 1,3 Nintendo Switch OLED Model Dock USB-C Assembly Replacement, Remove the baseplate: 步骤 6 中的图像 2,3 Nintendo Switch OLED Model Dock USB-C Assembly Replacement, Remove the baseplate: 步骤 6 中的图像 3,3
    • Use your fingers to pull the baseplate away from the frame and release it from its plastic clips.
    • Remove the baseplate.
  7. Nintendo Switch OLED Model Dock USB-C Assembly Replacement, Disconnect the motherboard: 步骤 7 中的图像 1,2 Nintendo Switch OLED Model Dock USB-C Assembly Replacement, Disconnect the motherboard: 步骤 7 中的图像 2,2
    • Use the flat end of a spudger to lift up the small locking flap on the motherboard cable's ZIF connector.
  8. Nintendo Switch OLED Model Dock USB-C Assembly Replacement: 步骤 8 中的图像 1,2 Nintendo Switch OLED Model Dock USB-C Assembly Replacement: 步骤 8 中的图像 2,2
    在这个步骤中使用的工具:
    • Use a pair of tweezers to slide the cable out of its connector.
  9. Nintendo Switch OLED Model Dock USB-C Assembly Replacement, Remove the motherboard: 步骤 9 中的图像 1,3 Nintendo Switch OLED Model Dock USB-C Assembly Replacement, Remove the motherboard: 步骤 9 中的图像 2,3 Nintendo Switch OLED Model Dock USB-C Assembly Replacement, Remove the motherboard: 步骤 9 中的图像 3,3
    • Use your finger to pull back on the plastic release tabs holding the motherboard in place.
    • Pull the motherboard up and away from the frame to remove it.
    • Don't fully remove the motherboard yet, as it's still connected to the frame via a JST cable.
    • Rest the motherboard by the frame before moving on to the next step.
  10. Nintendo Switch OLED Model Dock USB-C Assembly Replacement, Disconnect the LED: 步骤 10 中的图像 1,2 Nintendo Switch OLED Model Dock USB-C Assembly Replacement, Disconnect the LED: 步骤 10 中的图像 2,2
    • Use blunt tweezers, or your fingers, to pull the LED's JST connector out of its socket.
  11. Nintendo Switch OLED Model Dock USB-C Assembly Replacement, Unfasten the USB-C assembly: 步骤 11 中的图像 1,2 Nintendo Switch OLED Model Dock USB-C Assembly Replacement, Unfasten the USB-C assembly: 步骤 11 中的图像 2,2
    • Use a Phillips screwdriver to remove the four 6.9 mm screws securing the USB-C assembly to the frame.
  12. Nintendo Switch OLED Model Dock USB-C Assembly Replacement, Remove the USB-C assembly: 步骤 12 中的图像 1,2 Nintendo Switch OLED Model Dock USB-C Assembly Replacement, Remove the USB-C assembly: 步骤 12 中的图像 2,2
    • Remove the top-most portion of the assembly.
  13. Nintendo Switch OLED Model Dock USB-C Assembly Replacement: 步骤 13 中的图像 1,2 Nintendo Switch OLED Model Dock USB-C Assembly Replacement: 步骤 13 中的图像 2,2
    • Depending on how you disassembled the dock, the springs may still be connected to the top-most portion of the assembly.
    • Remove the two springs.
  14. Nintendo Switch OLED Model Dock USB-C Assembly Replacement: 步骤 14 中的图像 1,2 Nintendo Switch OLED Model Dock USB-C Assembly Replacement: 步骤 14 中的图像 2,2
    • Remove the bottom-most portion of the assembly.
结论
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Nintendo Switch OLED Answers community for help.
2等其他人完成本指南。
Alex Diaz-Kokaisl
于01/16/22注册
213,742 声望
创作了1,041篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了23,729篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 12
过去 7 天: 64
过去 30 天: 229
总计 9,851
