跳转到主内容
Nintendo Switch OLED Model Dock Front Case Replacement
你所需要的
  1. Nintendo Switch OLED Model Dock Front Case Replacement, Remove the rear cover: 步骤 1 中的图像 1,3 Nintendo Switch OLED Model Dock Front Case Replacement, Remove the rear cover: 步骤 1 中的图像 2,3 Nintendo Switch OLED Model Dock Front Case Replacement, Remove the rear cover: 步骤 1 中的图像 3,3
    • Use your fingers to pull the rear cover away from the frame and release its plastic clips.
    • Remove the rear cover.
  2. Nintendo Switch OLED Model Dock Front Case Replacement, Unfasten the baseplate: 步骤 2 中的图像 1,2 Nintendo Switch OLED Model Dock Front Case Replacement, Unfasten the baseplate: 步骤 2 中的图像 2,2
    • Use a Y0 screwdriver to unfasten the 7.5 mm-long screw securing the baseplate to the frame.
  3. Nintendo Switch OLED Model Dock Front Case Replacement, Remove the screw cover: 步骤 3 中的图像 1,3 Nintendo Switch OLED Model Dock Front Case Replacement, Remove the screw cover: 步骤 3 中的图像 2,3 Nintendo Switch OLED Model Dock Front Case Replacement, Remove the screw cover: 步骤 3 中的图像 3,3
    • Insert an opening tool between the frame and the plastic screw cover at the bottom-left corner.
    • Pry up with the opening tool to separate the screw cover from the frame.
    • Remove the screw cover.
  4. Nintendo Switch OLED Model Dock Front Case Replacement, Unfasten the midframe: 步骤 4 中的图像 1,2 Nintendo Switch OLED Model Dock Front Case Replacement, Unfasten the midframe: 步骤 4 中的图像 2,2
    • Use a Y0 screwdriver to remove the seven screws securing the midframe to the frame:
    • Four 3.9 mm screws
    • Three 7.5 mm screws
    • One 3.9 mm screw
  5. Nintendo Switch OLED Model Dock Front Case Replacement, Remove the midframe: 步骤 5 中的图像 1,3 Nintendo Switch OLED Model Dock Front Case Replacement, Remove the midframe: 步骤 5 中的图像 2,3 Nintendo Switch OLED Model Dock Front Case Replacement, Remove the midframe: 步骤 5 中的图像 3,3
    • Use your fingers to remove the midframe from the frame.
  6. Nintendo Switch OLED Model Dock Front Case Replacement, Remove the baseplate: 步骤 6 中的图像 1,3 Nintendo Switch OLED Model Dock Front Case Replacement, Remove the baseplate: 步骤 6 中的图像 2,3 Nintendo Switch OLED Model Dock Front Case Replacement, Remove the baseplate: 步骤 6 中的图像 3,3
    • Use your fingers to pull the baseplate away from the frame and release it from its plastic clips.
    • Remove the baseplate.
  7. Nintendo Switch OLED Model Dock Front Case Replacement, Disconnect the motherboard: 步骤 7 中的图像 1,2 Nintendo Switch OLED Model Dock Front Case Replacement, Disconnect the motherboard: 步骤 7 中的图像 2,2
    • Use the flat end of a spudger to lift up the small locking flap on the motherboard cable's ZIF connector.
  8. Nintendo Switch OLED Model Dock Front Case Replacement: 步骤 8 中的图像 1,2 Nintendo Switch OLED Model Dock Front Case Replacement: 步骤 8 中的图像 2,2
    在这个步骤中使用的工具:
    • Use a pair of tweezers to slide the cable out of its connector.
  9. Nintendo Switch OLED Model Dock Front Case Replacement, Remove the motherboard: 步骤 9 中的图像 1,3 Nintendo Switch OLED Model Dock Front Case Replacement, Remove the motherboard: 步骤 9 中的图像 2,3 Nintendo Switch OLED Model Dock Front Case Replacement, Remove the motherboard: 步骤 9 中的图像 3,3
    • Use your finger to pull back on the plastic release tabs holding the motherboard in place.
    • Pull the motherboard up and away from the frame to remove it.
    • Don't fully remove the motherboard yet, as it's still connected to the frame via a JST cable.
    • Rest the motherboard by the frame before moving on to the next step.
  10. Nintendo Switch OLED Model Dock Front Case Replacement, Disconnect the LED: 步骤 10 中的图像 1,2 Nintendo Switch OLED Model Dock Front Case Replacement, Disconnect the LED: 步骤 10 中的图像 2,2
    • Use blunt tweezers, or your fingers, to pull the LED's JST connector out of its socket.
  11. Nintendo Switch OLED Model Dock Front Case Replacement, Unfasten the USB-C assembly: 步骤 11 中的图像 1,2 Nintendo Switch OLED Model Dock Front Case Replacement, Unfasten the USB-C assembly: 步骤 11 中的图像 2,2
    • Use a Phillips screwdriver to remove the four 6.9 mm screws securing the USB-C assembly to the frame.
  12. Nintendo Switch OLED Model Dock Front Case Replacement, Remove the USB-C assembly: 步骤 12 中的图像 1,2 Nintendo Switch OLED Model Dock Front Case Replacement, Remove the USB-C assembly: 步骤 12 中的图像 2,2
    • Remove the top-most portion of the assembly.
  13. Nintendo Switch OLED Model Dock Front Case Replacement: 步骤 13 中的图像 1,2 Nintendo Switch OLED Model Dock Front Case Replacement: 步骤 13 中的图像 2,2
    • Depending on how you disassembled the dock, the springs may still be connected to the top-most portion of the assembly.
    • Remove the two springs.
  14. Nintendo Switch OLED Model Dock Front Case Replacement: 步骤 14 中的图像 1,2 Nintendo Switch OLED Model Dock Front Case Replacement: 步骤 14 中的图像 2,2
    • Remove the bottom-most portion of the assembly.
  15. Nintendo Switch OLED Model Dock Front Case Replacement, Unfasten the middle case's top half: 步骤 15 中的图像 1,2 Nintendo Switch OLED Model Dock Front Case Replacement, Unfasten the middle case's top half: 步骤 15 中的图像 2,2
    • Use a Phillips driver to remove the eight 6.9 mm screws securing the middle case to the frame.
  16. Nintendo Switch OLED Model Dock Front Case Replacement, Remove the middle case's top half: 步骤 16 中的图像 1,2 Nintendo Switch OLED Model Dock Front Case Replacement, Remove the middle case's top half: 步骤 16 中的图像 2,2
    • Use your finger to release the middle case's top half from its plastic clips located around the perimeter of the frame.
  17. Nintendo Switch OLED Model Dock Front Case Replacement: 步骤 17 中的图像 1,2 Nintendo Switch OLED Model Dock Front Case Replacement: 步骤 17 中的图像 2,2
    • Use your fingers to separate the two halves of the middle case.
  18. Nintendo Switch OLED Model Dock Front Case Replacement: 步骤 18 中的图像 1,3 Nintendo Switch OLED Model Dock Front Case Replacement: 步骤 18 中的图像 2,3 Nintendo Switch OLED Model Dock Front Case Replacement: 步骤 18 中的图像 3,3
    • Pull the middle case's top half through the top of the frame, making sure to angle the plastic clips upward.
  19. Nintendo Switch OLED Model Dock Front Case Replacement, Unfasten the middle case's bottom half: 步骤 19 中的图像 1,2 Nintendo Switch OLED Model Dock Front Case Replacement, Unfasten the middle case's bottom half: 步骤 19 中的图像 2,2
    • Use a Phillips driver to remove the two 4.4 mm screws securing the middle case's bottom half to the front cover.
  20. Nintendo Switch OLED Model Dock Front Case Replacement, Remove the middle case's bottom half: 步骤 20 中的图像 1,3 Nintendo Switch OLED Model Dock Front Case Replacement, Remove the middle case's bottom half: 步骤 20 中的图像 2,3 Nintendo Switch OLED Model Dock Front Case Replacement, Remove the middle case's bottom half: 步骤 20 中的图像 3,3
    • Insert an opening pick between the middle case's bottom half and the frame.
    • Slide the pick along the vertical edge of the middle case's bottom half to release the plastic clips securing it to the front cover.
  21. Nintendo Switch OLED Model Dock Front Case Replacement: 步骤 21 中的图像 1,3 Nintendo Switch OLED Model Dock Front Case Replacement: 步骤 21 中的图像 2,3 Nintendo Switch OLED Model Dock Front Case Replacement: 步骤 21 中的图像 3,3
    • Continue sliding the pick along the horizontal edge of the middle case's bottom half to release the plastic clips.
  22. Nintendo Switch OLED Model Dock Front Case Replacement: 步骤 22 中的图像 1,3 Nintendo Switch OLED Model Dock Front Case Replacement: 步骤 22 中的图像 2,3 Nintendo Switch OLED Model Dock Front Case Replacement: 步骤 22 中的图像 3,3
    • Pry up with the pick to completely separate the middle case's bottom half from the frame.
    • If you're still feeling resistance, slide the pick around the perimeter again until the middle case's bottom half is separated.
  23. Nintendo Switch OLED Model Dock Front Case Replacement: 步骤 23 中的图像 1,3 Nintendo Switch OLED Model Dock Front Case Replacement: 步骤 23 中的图像 2,3 Nintendo Switch OLED Model Dock Front Case Replacement: 步骤 23 中的图像 3,3
    • Use your fingers to pull and remove the middle case's bottom half from the front cover.
  24. Nintendo Switch OLED Model Dock Front Case Replacement, Remove the dock LED: 步骤 24 中的图像 1,3 Nintendo Switch OLED Model Dock Front Case Replacement, Remove the dock LED: 步骤 24 中的图像 2,3 Nintendo Switch OLED Model Dock Front Case Replacement, Remove the dock LED: 步骤 24 中的图像 3,3
    在这个步骤中使用的工具:
    • Use tweezers, or your fingers, to remove the dock LED from the frame.
  25. Nintendo Switch OLED Model Dock Front Case Replacement, Only the front case remains: 步骤 25 中的图像 1,1
    • You're now left with the front case.
结论
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Nintendo Switch OLED Answers community for help.
2等其他人完成本指南。
Alex Diaz-Kokaisl
于01/16/22注册
214,294 声望
创作了1,041篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了23,758篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 43
过去 30 天: 167
总计 13,971
