简介
This is an archived guide. The updated version can be found here.
Press and hold down the small round button on the back of the Joy Con controller.
While you hold down the button, slide the controller upward.
Continue sliding the controller upward until it's completely removed from the console.
Use a Y00 screwdriver to remove the four 6.3 mm-long screws securing the rear panel.
Use a JIS 000 screwdriver to remove the following screws securing the rear panel:
One 2.5 mm-long screw on the top edge of the device
Two 2.5 mm-long screws on the bottom edge of the device
Use a JIS 000 screwdriver to remove the 3.1 mm screw securing the microSD card reader to the device.
Use a JIS 000 screwdriver to remove the six 3 mm screws securing the shield plate to the device.
Use the point of a spudger to pry the battery connector straight up and out of its socket on the motherboard.
Use a JIS 000 screwdriver to remove the three 3 mm screws securing the heat sink to the motherboard.
Remove the two 3.1 mm Phillips screws from the headphone jack bracket.
