跳转到主内容
加入维修社区 - 创建账户
Nintendo GameCube Front and Back Panel Replacement
你所需要的
    1. Nintendo GameCube Front and Back Panel Replacement, Top Case: 步骤 1 中的图像 1,3 Nintendo GameCube Front and Back Panel Replacement, Top Case: 步骤 1 中的图像 2,3 Nintendo GameCube Front and Back Panel Replacement, Top Case: 步骤 1 中的图像 3,3
      • Turn over the Gamecube so that the bottom side is facing up.
      • Use the 4.5 mm Gamebit screwdriver to remove all four screws.
      询问修复机器人
      添加评论
    2. Nintendo GameCube Front and Back Panel Replacement: 步骤 2 中的图像 1,3 Nintendo GameCube Front and Back Panel Replacement: 步骤 2 中的图像 2,3 Nintendo GameCube Front and Back Panel Replacement: 步骤 2 中的图像 3,3
      • With the bottom side of the GameCube facing upward and the screws removed, carefully pull the outer shell of the unit away from the top half.
      • Move the GameCube so that the inside is facing upwards.
      添加评论
    1. Nintendo GameCube Front and Back Panel Replacement, Removing the back panel: 步骤 3 中的图像 1,1
      • Gently press down on the clips located on either side of the back panel.
      • Carefully remove the back panel from the GameCube.
      添加评论
    2. Nintendo GameCube Front and Back Panel Replacement: 步骤 4 中的图像 1,1
      • Unclip the controller ports at the front of the unit.
      • A ribbon cable (outlined in orange) is still attached to the unit. Do not disconnect this cable.
      • Controller ports are where the controllers plug into the game console, and are a half circular shape.
      添加评论
    3. Nintendo GameCube Front and Back Panel Replacement, Separate the casing: 步骤 5 中的图像 1,2 Nintendo GameCube Front and Back Panel Replacement, Separate the casing: 步骤 5 中的图像 2,2
      • This step may not be necessary depending on your end goal
      • Use a Phillips #2 screwdriver to remove the two screws on the back of the control port.
      • Carefully separate the gray outer casing of the control port and the circuit board.
      添加评论
结论
取消:我没有完成这个指南。
6等其他人完成本指南。
dcarlin
于11/05/09注册
399 声望
创作了4篇指南
团队
Cal Poly, Team 6-2, Maness Fall 2009 Cal Poly, Team 6-2, Maness Fall 2009 的会员
CPSU-MANESS-F09S6G2
4 名成员
创作了53篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 26
过去 30 天: 121
总计 19,091
