跳转到主内容
加入维修社区 - 创建账户
Nintendo Entertainment System Controller Cable Replacement
你所需要的
  1. Nintendo Entertainment System Controller Cable Replacement, Back Cover Removal: 步骤 1 中的图像 1,2 Nintendo Entertainment System Controller Cable Replacement, Back Cover Removal: 步骤 1 中的图像 2,2
    • Remove the 6 8mm screws in the back cover using a #1 Philips screwdriver.
  2. Nintendo Entertainment System Controller Cable Replacement, Loosen Cable: 步骤 2 中的图像 1,1
    • Lift the back cover off the controller.
    • Remove the cable from its holders to facilitate PCB removal.
  3. Nintendo Entertainment System Controller Cable Replacement, PCB Removal: 步骤 3 中的图像 1,1
    • Lift the PCB straight up and out of the controller. Turn the board over to access the solder joints for the cable.
    • Desolder the 5 connections and solder in your new cable.
    • Wire colors are printed on the reverse side of the board.
结论
另外一个人完成了本指南。
themap504
于01/08/15注册
80 声望
撰写一个指南
2指南评论
My replacement plugs have different colors. Colors are yellow, white, red, black, and green. I’m also doing a max controller not regular nes controller. The max has yellow, red, white, red, and orange color schemes. Any advice. I wired up same colors and guessed for rest. figured black could replace one of the reds, and used green to replace orange, but console just resets over and over with that controller plugged in.
Daniel Melvin - 回复 分享
Check for continuity from the pins on the plug side with the wires and soldier them in the corresponding spot, i:e if red is power then you soldier it to the power slot on the motherboard and so on. Check if you can find a instruction book on the controller.
Cgull - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 21
过去 30 天: 81
总计 2,915
