简介
This is a fairly straight forward repair. Soldering skills are required.
Still possible even if you've only soldered twice in your life and are afraid you'll make a mess of it. You know who you are ;)
你所需要的
Remove the 6 8mm screws in the back cover using a #1 Philips screwdriver.
Lift the back cover off the controller.
Remove the cable from its holders to facilitate PCB removal.
Lift the PCB straight up and out of the controller. Turn the board over to access the solder joints for the cable.
Desolder the 5 connections and solder in your new cable.
另外一个人完成了本指南。
2指南评论
My replacement plugs have different colors. Colors are yellow, white, red, black, and green. I’m also doing a max controller not regular nes controller. The max has yellow, red, white, red, and orange color schemes. Any advice. I wired up same colors and guessed for rest. figured black could replace one of the reds, and used green to replace orange, but console just resets over and over with that controller plugged in.
