跳转到主内容
Nintendo DSi Top LCD Screen Replacement
已存档的指南
本指南只作为历史记录保留。请使用指南的最新版本来进行维修。
你所需要的
  1. 注意:步骤 1-2 源自标记为进行中的 指南
    Nintendo DSi Top LCD Screen Replacement, Battery: 步骤 1 中的图像 1,1
    • Loosen the two screws on the battery panel. Then lift the panel up to remove it.
  2. Nintendo DSi Top LCD Screen Replacement: 步骤 2 中的图像 1,1
    • L Button.
    • Top of the battery pack.
    • To remove the battery pack, place your fingernail or a spudger at the top of the battery near the L button. Gently lift the battery out.
  3. 注意:步骤 3-4 源自标记为进行中的 指南
    Nintendo DSi Top LCD Screen Replacement, Motherboard: 步骤 3 中的图像 1,2 Nintendo DSi Top LCD Screen Replacement, Motherboard: 步骤 3 中的图像 2,2
    • Remove 4 Phillips screws from the board.
    • Lift the main board from the bottom end and flip it over to reveal the last connector.
    • Keep the main board fairly close to the case, making sure not to damage the last ribbon cable holding it in place.
  4. Nintendo DSi Top LCD Screen Replacement: 步骤 4 中的图像 1,1
    • Disconnect the ribbon cable by gently using a plastic opening tool to flip up the black connector latch. The cable should easily slide out from the connector.
    • The motherboard should now be free from the rest of the device.
  5. Nintendo DSi Top LCD Screen Replacement, Bottom Case: 步骤 5 中的图像 1,1
    • Remove the rubber front-panel button membranes from the device. Pay careful attention to where the buttons go, so you can replace them correctly.
    • A/B/X/Y button assembly
    • Select/Start button assembly
    • D-pad
    • Power button
  6. Nintendo DSi Top LCD Screen Replacement: 步骤 6 中的图像 1,2 Nintendo DSi Top LCD Screen Replacement: 步骤 6 中的图像 2,2
    • Remove the plastic buttons and keep them in a safe place.
    • All of the buttons have "key" notches to prevent them from being inserted incorrectly (backwards or in the wrong place), but it can take a while to figure out where everything goes if they get shuffled around.
  7. Nintendo DSi Top LCD Screen Replacement: 步骤 7 中的图像 1,2 Nintendo DSi Top LCD Screen Replacement: 步骤 7 中的图像 2,2
    • Flip the case open, and push the lower screen assembly out of the frame.
  8. Nintendo DSi Top LCD Screen Replacement, Top LCD Screen: 步骤 8 中的图像 1,1
    • To make the repair easier, we recommend removing the bottom LCD screen prior to replacing the top LCD screen.
    • Using a spudger, or similar tool, pry out the 4 square screw covers.
  9. Nintendo DSi Top LCD Screen Replacement: 步骤 9 中的图像 1,1
    • Remove 4 Phillips screws with a #00 Phillips screwdriver.
  10. Nintendo DSi Top LCD Screen Replacement: 步骤 10 中的图像 1,1
    • Place a plastic opening tool between the front panel and top edge of the outer case. Slide the tool along the edge as needed to prop open the case.
    • With the screen facing you, slide the screen side down with your thumbs to separate the screen from the cover.
  11. Nintendo DSi Top LCD Screen Replacement: 步骤 11 中的图像 1,1
    • Remove the antenna from the bottom left of the device.
    • Remove the microphone from the top of the frame.
  12. Nintendo DSi Top LCD Screen Replacement: 步骤 12 中的图像 1,1
    • Use a spudger to pry the camera out of its place.
  13. Nintendo DSi Top LCD Screen Replacement: 步骤 13 中的图像 1,1
    • Cables for the components in the upper half of the device run through the hinge, which must be carefully disassembled before continuing.
    • Start by pushing the sliding shaft in the hinge on the opposite side of the wires/ribbons.
  14. Nintendo DSi Top LCD Screen Replacement: 步骤 14 中的图像 1,1
    • On the reverse side of the casing, insert the spudger onto the surface of the sliding shaft just left of the LED light channels.
    • Push the sliding shaft completely through the hinge until it stops and the hinge is released.
  15. Nintendo DSi Top LCD Screen Replacement: 步骤 15 中的图像 1,1
    • The right side of bottom case should separate from the top case when you remove the sliding shaft.
    • Do not pull up too far or the wire hinge may be damaged.
    • Slide the top case to the right to separate the joint.
    • Weave the wires and ribbons through the wire hinge to completely separate the top and bottom casings.
  16. Nintendo DSi Top LCD Screen Replacement: 步骤 16 中的图像 1,2 Nintendo DSi Top LCD Screen Replacement: 步骤 16 中的图像 2,2
    • The speakers are soldered to the ribbon cable attached to the upper LCD, so they must be removed at the same time as the LCD.
    • Lift the top LCD out of the plastic frame. Carefully thread the ribbon cable out of the hinge to avoid damaging it.
  17. Nintendo DSi Top LCD Screen Replacement: 步骤 17 中的图像 1,1
    • To remove the speakers, use a spudger or a similar tool to gently pry them off.
结论
另外一个人完成了本指南。
rjcamero
于11/05/09注册
50 声望
创作了3篇指南
团队
Cal Poly, Team 6-1, Maness Fall 2009 Cal Poly, Team 6-1, Maness Fall 2009 的会员
CPSU-MANESS-F09S6G1
5 名成员
创作了4篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 11
过去 7 天: 119
过去 30 天: 540
总计 38,505
