跳转到主内容
加入维修社区 - 创建账户
Disassembling Nintendo DSi Bottom case
已存档的指南
本指南只作为历史记录保留。请使用指南的最新版本来进行维修。
你所需要的
    1. 注意:步骤 1-2 源自标记为进行中的 指南
      Disassembling Nintendo DSi Bottom case, Battery: 步骤 1 中的图像 1,1
      • Loosen the two screws on the battery panel. Then lift the panel up to remove it.
      询问修复机器人
      添加评论
    2. Disassembling Nintendo DSi Bottom case: 步骤 2 中的图像 1,1
      • L Button.
      • Top of the battery pack.
      • To remove the battery pack, place your fingernail or a spudger at the top of the battery near the L button. Gently lift the battery out.
      添加评论
    1. 注意:步骤 3-4 源自标记为进行中的 指南
      Disassembling Nintendo DSi Bottom case, Motherboard: 步骤 3 中的图像 1,2 Disassembling Nintendo DSi Bottom case, Motherboard: 步骤 3 中的图像 2,2
      • Remove 4 Phillips screws from the board.
      • Lift the main board from the bottom end and flip it over to reveal the last connector.
      • Keep the main board fairly close to the case, making sure not to damage the last ribbon cable holding it in place.
      询问修复机器人
      添加评论
    2. Disassembling Nintendo DSi Bottom case: 步骤 4 中的图像 1,1
      • Disconnect the ribbon cable by gently using a plastic opening tool to flip up the black connector latch. The cable should easily slide out from the connector.
      • The motherboard should now be free from the rest of the device.
      询问修复机器人
      添加评论
    1. Disassembling Nintendo DSi Bottom case, Bottom Case: 步骤 5 中的图像 1,1
      • Remove the rubber front-panel button membranes from the device. Pay careful attention to where the buttons go, so you can replace them correctly.
      • A/B/X/Y button assembly
      • Select/Start button assembly
      • D-pad
      • Power button
      询问修复机器人
      添加评论
    2. Disassembling Nintendo DSi Bottom case: 步骤 6 中的图像 1,2 Disassembling Nintendo DSi Bottom case: 步骤 6 中的图像 2,2
      • Remove the plastic buttons and keep them in a safe place.
      • All of the buttons have "key" notches to prevent them from being inserted incorrectly (backwards or in the wrong place), but it can take a while to figure out where everything goes if they get shuffled around.
      询问修复机器人
      添加评论
    3. Disassembling Nintendo DSi Bottom case: 步骤 7 中的图像 1,2 Disassembling Nintendo DSi Bottom case: 步骤 7 中的图像 2,2
      • Flip the case open, and push the lower screen assembly out of the frame.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
rjcamero
于11/05/09注册
56 声望
创作了3篇指南
团队
Cal Poly, Team 6-1, Maness Fall 2009 Cal Poly, Team 6-1, Maness Fall 2009 的会员
CPSU-MANESS-F09S6G1
5 名成员
创作了42篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 22
过去 30 天: 84
总计 7,213
