跳转到主内容
此翻译可能不反映源指南的最新更新。 帮助更新翻译查看源指南
Nintendo 3DS XL 2015 A,B,X,Y, Start或Select按钮维修
你所需要的
  1. Nintendo 3DS XL 2015 A,B,X,Y, Start或Select按钮维修, 电池: 步骤 1 中的图像 1,1
    • 在继续操作之前,请确保你的设备已关闭电源。否则可能导致电击或损坏设备。
    • 将3DS倒置。取出游戏卡、耳机、充电线、手写笔或其他可能与设备连接的东西。
  2. Nintendo 3DS XL 2015 A,B,X,Y, Start或Select按钮维修: 步骤 2 中的图像 1,1
    • 使用JIS 0号螺丝刀,松开背面的两个黑色螺丝。
    • 螺丝是被固定在壳上的,不应完全拆除。
    My experience indicates that a JIS #1 is more appropriate here.
    John Menden - 回复
    Same here, much more appropriate.
    Jack Wilson -
  3. Nintendo 3DS XL 2015 A,B,X,Y, Start或Select按钮维修: 步骤 3 中的图像 1,1
    • 螺丝松动后,撬开后盖。
    In order to remove the back cover, slide it down towards you and then pry the cover off.
    Jon Fukumoto - 回复
  4. Nintendo 3DS XL 2015 A,B,X,Y, Start或Select按钮维修: 步骤 4 中的图像 1,1
    • 电池位于3DS的左手边--要取下,利用位于中上部的小缝隙,用撬棒拉起。
    Also you should remove any SD card at this point
    James Grant - 回复
    Does this battery work on a NEW 3DS XL model?
    Froggy The Frog - 回复
    This guide is for the New 3DS XL, which is called the 2015 3DS XL here on iFixit. If you're asking about the 3DS replacement battery advertised in the iFixit store, I believe it works for both new and old models.
    BabblingFishes -
    The battery is the same and will work on both the new and old models
    Jon Fukumoto - 回复
  5. Nintendo 3DS XL 2015 A,B,X,Y, Start或Select按钮维修, A,B,X,Y, Start 或Select 按钮: 步骤 5 中的图像 1,1
    • 用JIS#000螺丝刀卸下副面板上的6毫米螺丝。
    the heck. on step 5 im using the 000 screwdriver from the kit and i am destroying the screw, yes going counter clockwise.
    the j000 and 000 don't work. im using the toolkit from your site and i don't see a JIS #000 just J000 and 000
    edit: so the j00 works.
    stephankranenfeld - 回复
    DO NOT DO THIS. Use a JIS #00 screwdriver instead. I damaged two of my screws when using a JIS #000 screwdriver to remove them, now they need to be replaced. Also, make sure to hold down on the secondary panel while removing it's screws.
    Jaden N - 回复
  6. Nintendo 3DS XL 2015 A,B,X,Y, Start或Select按钮维修: 步骤 6 中的图像 1,2 Nintendo 3DS XL 2015 A,B,X,Y, Start或Select按钮维修: 步骤 6 中的图像 2,2
    • 取下位于充电口两侧的两个上层胶垫。
    • 使用JIS#00螺丝刀,小心地卸下看见的两个6毫米的螺丝。
    A #0 worked better for me than the #00
    Lucas M - 回复
    All 8 screws from Step 5 to 6 are the same size and should be pulled out using a #000 screwdriver.
    Alan Chen - 回复
  7. Nintendo 3DS XL 2015 A,B,X,Y, Start或Select按钮维修: 步骤 7 中的图像 1,3 Nintendo 3DS XL 2015 A,B,X,Y, Start或Select按钮维修: 步骤 7 中的图像 2,3 Nintendo 3DS XL 2015 A,B,X,Y, Start或Select按钮维修: 步骤 7 中的图像 3,3
    • 要撬开盖子,要小心地把它抬起来,然后把它向图中那个方向小心翼翼转向那边,露出电路板。
  8. Nintendo 3DS XL 2015 A,B,X,Y, Start或Select按钮维修: 步骤 8 中的图像 1,1
    • 用不导电的镊子断开连接盖板上L/R/ZL/ZR按钮和主板的两个排线挑开,然后完全取下。
  9. Nintendo 3DS XL 2015 A,B,X,Y, Start或Select按钮维修: 步骤 9 中的图像 1,3 Nintendo 3DS XL 2015 A,B,X,Y, Start或Select按钮维修: 步骤 9 中的图像 2,3 Nintendo 3DS XL 2015 A,B,X,Y, Start或Select按钮维修: 步骤 9 中的图像 3,3
    • 找到主板和左侧电路板之间的排线(它应该是最宽的),用镊子将ZIF卡扣向上拨开。
    • 可以用不导电的镊子将排线与电路板平行拉出,将其取出。
  10. Nintendo 3DS XL 2015 A,B,X,Y, Start或Select按钮维修: 步骤 10 中的图像 1,1
    • 接下来,找到左边电路板上的5个3毫米螺丝,用JIS#000螺丝刀将其卸下。
  11. Nintendo 3DS XL 2015 A,B,X,Y, Start或Select按钮维修: 步骤 11 中的图像 1,1
    • 小心地把板子翻过来,用镊子取出位于下面的蓝黑色排线。
    Closely examine the connection before removing the ribbon from the board!
    The C-stick ribbon is secured to the action board at the socket by a black tab that must be unlocked (swiveled up) before the ribbon is free to be removed. Yanking the ribbon from the locked connector may break off the lock and you'll be forced to replace the entire board.
    The easier way to do this is to leave this ribbon connected. Go back to Step 10 and remove the three black screws securing the C-stick unit to the frame. Remove the C-stick unit along with the board and move onto Step 12.
    THRILLHOUSE - 回复
  12. Nintendo 3DS XL 2015 A,B,X,Y, Start或Select按钮维修: 步骤 12 中的图像 1,1
    • 取下灰色的大片的按键导胶,可以看到A/B/X/Y按钮,下方长方形的按键导胶拿下就可以看到start和select按钮。
    • 用镊子取下按键。
    • 更换时,一定要检查每个按钮是否放回原处,并紧贴在相应的孔中,然后再重新组装设备。
    It would be good to show photos how to carefully peel off the membrane, so that the contacts can be cleaned, or replaced. This is shown in white on the PCB on photo 11. I put further details further down where someone asked a question. This applies to other 3DS models too
    Andrew - 回复
结论
要重新组装你的设备,请按照这些说明以相反的顺序进行。
27等其他人完成本指南。
由衷感谢以下译者:
en zh
66%
Xavier正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
Kobbe Farwick
于04/01/15注册
2,347 声望
创作了2篇指南
团队
Cal Poly, Team 24-4, Lancaster Spring 2015 Cal Poly, Team 24-4, Lancaster Spring 2015 的会员
CPSU-LANCASTER-S15S24G4
4 名成员
创作了30篇指南
15条评论
do the smaller new 3ds colored buttons work in the new 3ds xl?
itsandy14 - 回复
It will work, since the only difference between them is the size of screen and shell, but size of buttons and other pieces should be of the same.
CheatJoker -
If anyone else comes on this, I can confirm the small 3ds buttons do not quite work right they are slightly smaller and the cut outs that keep the buttons from spinning around are not the same
Demon09 -
Can someone provide further information about replacement of the entire C stick?
Or is it just as simple as pull the ribbon carefully, take the old one out and put the new one in?
CheatJoker - 回复
There are two parts. The rubber bit, and the joystick assembly. The stick assembly is connected by 3 short screws, and inserted into the joystick board via zif connector. You need to unscrew the assembly to access the rubber bit.
Mogamad Lilla -
The set of screws on the secondary panel are giving me trouble. I think I might be stripping them... Is it normal for them to be screwed on so tight? I don't want to pay 85 bucks just because I need to press my B button harder to make it work...
Ben Fuqua - 回复
One of the screw of the second set was also giving me trouble. Just press firmly and turn very slowly. As they are not supposed to be touched by the consumer, I suspect they put a kind of sealant to make them harder to unscrew.
Alex Lebeau -
Mine were tight as well, make sure you're using JIS and not Philips and you should be fine. Since this is seven years later I hope you've fixed it though!
Isak -
One thing to note is that the kit that I received from ifixit had the c-stick nub attached to the board. As such, you'll want to remove the c-stick instead of disconnecting the ribbon.
Jason Thompson - 回复
Would be cool to provide in every section a place where users can offer a paid service to repair devices other users are afraid to repair.
theoctopusride - 回复
Does annyone know what is wrong with my new 3ds xl... So all buttons work fine BUT the a button needs alot of pressure to work. Tried to clean it but idk still needs way more pressure than the rest…
TMHate MK - 回复
I had the same problem, the A button especially was very temperamental and had to push it very hard to trigger. I watched a video yesterday which showed carefully peeling the transparent membrane off with tweezers to get inside the metal domes (it's very sticky so was difficult to get it to start peeling, but comes away carefully once you manage to get it started, just don't peel too hard that it rips). This is what holds the 4 metal domes in place. I then cleaned them as there was slight corrosion in there. I then pushed the membrane down and reassembled where it now works perfectly. I then did the same with the D-pad which worked but didn't always trigger when it clicked but would it you pushed them slightly harder and they are working perfectly.
One tip, if possible, don't completely remove the transparent membrane. just peel it enough to gain access, so you can push back down .if you peel it completely you'll have to realign it perfectly, and if it doesn't line up they won't work. The tolerance is tight!
Andrew -
This guide doesn't mention that if a button is no longer working or needs to be pressed harder to work, that the contacts on the board shown in step 11 need to be replaced, not necessarily the board or the outer buttons themselves. This video shows how to replace the sticker containing the contacts. I plan to do this replacement myself when the replacement comes in. As of today, such a replacement costs about $10, whereas the board is about $15.
Isak - 回复
Turns out that you can't edit a comment after five minutes have passed, which is dumb.
IMPORTANT FOR ANYBODY ATTEMPTING THIS FIX: Try to clean the contacts beneath the contact sticker before you do any of these replacements. It will likely fix your issue. Just be careful to realign the sticker correctly, as Andrew posted above.
Isak -
Anybody know how to fix the home button on the new 3ds xl? I can push it down fine it just doesn't register.
user596 - 回复
添加评论
浏览统计数据:
过去 24 小时: 36
过去 7 天: 272
过去 30 天: 1,207
总计 51,659
