跳转到主内容
加入维修社区 - 创建账户
Nintendo 2DS Screen Replacement
你所需要的
  1. Nintendo 2DS Screen Replacement, Battery: 步骤 1 中的图像 1,1
    • Remove the two Phillips captive screws securing the upper rear panel.
    • The captive screws will not completely detach from the back panel.
    添加评论
  2. Nintendo 2DS Screen Replacement: 步骤 2 中的图像 1,2 Nintendo 2DS Screen Replacement: 步骤 2 中的图像 2,2
    • Hinge the upper rear panel upwards and outwards to remove it.
    添加评论
  3. Nintendo 2DS Screen Replacement: 步骤 3 中的图像 1,3 Nintendo 2DS Screen Replacement: 步骤 3 中的图像 2,3 Nintendo 2DS Screen Replacement: 步骤 3 中的图像 3,3
    • Remove the battery from its housing by lifting it up from the side closest to the outside edge.
    询问修复机器人
    添加评论
  4. Nintendo 2DS Screen Replacement, Rear Panel: 步骤 4 中的图像 1,1
    • Remove the ten Phillips screws attaching the rear panel.
    添加评论
  5. Nintendo 2DS Screen Replacement: 步骤 5 中的图像 1,1
    • The rear panel is attached to the motherboard by a ribbon cable, so be careful not to lift the rear panel too far from the device.
    • Carefully pull the rear panel straight up from the device.
    添加评论
  6. Nintendo 2DS Screen Replacement: 步骤 6 中的图像 1,1
    • Use your fingernail or the flat end of a spudger to flip up the connector securing the ribbon cable to the motherboard
    • Remove the cable from the connector
    • Take the opportunity to remove the Left and Right triggers, they have hinges that may break and springs that may jump away.
    添加评论
  7. Nintendo 2DS Screen Replacement, Remove Side Panels: 步骤 7 中的图像 1,2 Nintendo 2DS Screen Replacement, Remove Side Panels: 步骤 7 中的图像 2,2
    • Hold the side panels of the device's case with your fingers and pull outward to remove them.
    • The panels should come off easily with little force required.
    • There are three ribbon cables which have already been unplugged in this picture, disconnect these before disassembling the device further.
    添加评论
  8. Nintendo 2DS Screen Replacement, Unscrew Motherboard: 步骤 8 中的图像 1,1
    • Remove the 12 brass-colored Phillips screws securing the main board.
    • Be very careful not to strip any of these screws. Stripping can occur very easily, and may make replacement of the motherboard impossible.
    • The circle pad has disappeared in this picture. Don't worry, we'll deal with that in the next step
    添加评论
  9. Nintendo 2DS Screen Replacement, Remove Top Panel: 步骤 9 中的图像 1,3 Nintendo 2DS Screen Replacement, Remove Top Panel: 步骤 9 中的图像 2,3 Nintendo 2DS Screen Replacement, Remove Top Panel: 步骤 9 中的图像 3,3
    • The top panel can only be removed when the mother board is not secured.
    • There are two additional screws located on the top rail. Remove these to fully remove the buttons and top rail.
    • There are two screws holding down the joystick base that must be removed. (Be careful of the ribbon cable—it stays connected!)
    • Hold the top panel with your fingers and pull away from the device to remove it.
    • The top panel should come off easily, with very little force applied.
    添加评论
  10. Nintendo 2DS Screen Replacement, Remove Motherboard: 步骤 10 中的图像 1,2 Nintendo 2DS Screen Replacement, Remove Motherboard: 步骤 10 中的图像 2,2
    • Detach the 2 ribbon cables by lifting the black flip connectors that hold them.
    • Lift out the rectangular board seated in the face and lift out the white square which is the joystick motor (takes a little effort). Both stay attached to the motherboard.
    • On some models, you'll need to remove three more tiny ribbon cables at the bottom of the screen. They are secured by flip up connectors. BE GENTLE!
    • Holding the motherboard on either side, lift to remove it.
    添加评论
  11. Nintendo 2DS Screen Replacement, Screen Replacement: 步骤 11 中的图像 1,1
    • Ensure that the ribbon cables connecting the screen to the motherboard have been disconnected before removing the screen from the front panel casing.
    • Grasp the screen firmly by a corner and lift it off of the front panel of the Nintendo 2DS.
    • There should be slight resistance due to the double-sided adhesive strip on the screen.
    添加评论
结论
取消:我没有完成这个指南。
87等其他人完成本指南。
团队
Cal Poly, Team 70-1, Forte Winter 2015 Cal Poly, Team 70-1, Forte Winter 2015 的会员
CPSU-FORTE-W15S70G1
4 名成员
创作了36篇指南
31指南评论
Camera ribbon cable is very brittle, be careful.
Logan Pena - 回复 分享
Thank you so much, Fina! You have done a fantastic job explaining each step incredibly well! I very much appreciate all of your efforts into skillfully describing the process of disassembling the 2DS. I was able to understand your instructions and thus was able to make a lucky kiddo super happy! Thanks again!
-Skye
Skye Leah - 回复 分享
P.S. To those out there who don't have a super, ridiculously tiny (#000 screwdriver or 1.587 mm Phillips head) and don't want to have to purchase one just to complete this already daunting task, I found that using a screwdriver from a glasses repair kit worked PERFECTLY! :)
Skye Leah - 回复 分享
what about a new screen?
Lord Hohenheim (Sans) - 回复 分享
Once you've removed your screen, what are you supposed to do with it to clean and/or repair?
Danielle Chester - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 44
过去 7 天: 339
过去 30 天: 1,517
总计 191,936
