跳转到主内容
加入维修社区 - 创建账户
Nintendo 2DS Motherboard Replacement
你所需要的
  1. Nintendo 2DS Motherboard Replacement, Battery: 步骤 1 中的图像 1,1
    • Remove the two Phillips captive screws securing the upper rear panel.
    • The captive screws will not completely detach from the back panel.
    添加评论
  2. Nintendo 2DS Motherboard Replacement: 步骤 2 中的图像 1,2 Nintendo 2DS Motherboard Replacement: 步骤 2 中的图像 2,2
    • Hinge the upper rear panel upwards and outwards to remove it.
    添加评论
  3. Nintendo 2DS Motherboard Replacement: 步骤 3 中的图像 1,3 Nintendo 2DS Motherboard Replacement: 步骤 3 中的图像 2,3 Nintendo 2DS Motherboard Replacement: 步骤 3 中的图像 3,3
    • Remove the battery from its housing by lifting it up from the side closest to the outside edge.
    询问修复机器人
    添加评论
  4. Nintendo 2DS Motherboard Replacement, Rear Panel: 步骤 4 中的图像 1,1
    • Remove the ten Phillips screws attaching the rear panel.
    添加评论
  5. Nintendo 2DS Motherboard Replacement: 步骤 5 中的图像 1,1
    • The rear panel is attached to the motherboard by a ribbon cable, so be careful not to lift the rear panel too far from the device.
    • Carefully pull the rear panel straight up from the device.
    添加评论
  6. Nintendo 2DS Motherboard Replacement: 步骤 6 中的图像 1,1
    • Use your fingernail or the flat end of a spudger to flip up the connector securing the ribbon cable to the motherboard
    • Remove the cable from the connector
    • Take the opportunity to remove the Left and Right triggers, they have hinges that may break and springs that may jump away.
    添加评论
  7. Nintendo 2DS Motherboard Replacement, Remove Side Panels: 步骤 7 中的图像 1,2 Nintendo 2DS Motherboard Replacement, Remove Side Panels: 步骤 7 中的图像 2,2
    • Hold the side panels of the device's case with your fingers and pull outward to remove them.
    • The panels should come off easily with little force required.
    • There are three ribbon cables which have already been unplugged in this picture, disconnect these before disassembling the device further.
    添加评论
  8. Nintendo 2DS Motherboard Replacement, Unscrew Motherboard: 步骤 8 中的图像 1,1
    • Remove the 12 brass-colored Phillips screws securing the main board.
    • Be very careful not to strip any of these screws. Stripping can occur very easily, and may make replacement of the motherboard impossible.
    • The circle pad has disappeared in this picture. Don't worry, we'll deal with that in the next step
    添加评论
  9. Nintendo 2DS Motherboard Replacement, Remove Top Panel: 步骤 9 中的图像 1,3 Nintendo 2DS Motherboard Replacement, Remove Top Panel: 步骤 9 中的图像 2,3 Nintendo 2DS Motherboard Replacement, Remove Top Panel: 步骤 9 中的图像 3,3
    • The top panel can only be removed when the mother board is not secured.
    • There are two additional screws located on the top rail. Remove these to fully remove the buttons and top rail.
    • There are two screws holding down the joystick base that must be removed. (Be careful of the ribbon cable—it stays connected!)
    • Hold the top panel with your fingers and pull away from the device to remove it.
    • The top panel should come off easily, with very little force applied.
    添加评论
  10. Nintendo 2DS Motherboard Replacement, Remove Motherboard: 步骤 10 中的图像 1,2 Nintendo 2DS Motherboard Replacement, Remove Motherboard: 步骤 10 中的图像 2,2
    • Detach the 2 ribbon cables by lifting the black flip connectors that hold them.
    • Lift out the rectangular board seated in the face and lift out the white square which is the joystick motor (takes a little effort). Both stay attached to the motherboard.
    • On some models, you'll need to remove three more tiny ribbon cables at the bottom of the screen. They are secured by flip up connectors. BE GENTLE!
    • Holding the motherboard on either side, lift to remove it.
    添加评论
结论
取消:我没有完成这个指南。
34等其他人完成本指南。
Fina Beauchamp
于01/12/15注册
3,403 声望
创作了6篇指南
团队
Cal Poly, Team 70-1, Forte Winter 2015 Cal Poly, Team 70-1, Forte Winter 2015 的会员
CPSU-FORTE-W15S70G1
4 名成员
创作了36篇指南
13指南评论
o meu 2ds esta com um defeito que, quando eu aperto o botão de power ele liga e apos alguns segundo desliga e faz um pequeno barulho.
thiagopereira10000 - 回复 分享
Would a jis #000 screw driver work better? As i tried a ph +000 and the gold motherboard screws just dont fit right
Demon09 - 回复 分享
I have a question. After I replaced the mother board I have been having issues with it freezing after a couple mins running. Do you know why
briana1987be - 回复 分享
I have a similar problem. After I replaced mine it will not open any app, and it does not show the status bar. Does anyone know why?
Steve David - 回复 分享
Now that I've removed the motherboard, how do I fix it? The instructible is great as far as it goes, but it doesn't go far enough
Danielle Chester - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 12
过去 7 天: 140
过去 30 天: 603
总计 68,625
