跳转到主内容
加入维修社区 - 创建账户
Ninja Professional Blender BL660 Power Button Panel Replacement
你所需要的
    1. Ninja Professional Blender BL660 Power Button Panel Replacement, Blender Base: 步骤 1 中的图像 1,2 Ninja Professional Blender BL660 Power Button Panel Replacement, Blender Base: 步骤 1 中的图像 2,2
      • Using the Phillips #1 screwdriver, remove the 5 screws (13mm long, 6mm wide) holding the outer base.
      • Lift the base up to remove it.
      询问修复机器人
      添加评论
    2. Ninja Professional Blender BL660 Power Button Panel Replacement: 步骤 2 中的图像 1,2 Ninja Professional Blender BL660 Power Button Panel Replacement: 步骤 2 中的图像 2,2
      • Remove the midsection by pulling it up. If the section is stuck, use the iFixit plastic opening tool to pry it off.
      • Pull the power cord through the mid-section opening.
      询问修复机器人
      添加评论
    3. Ninja Professional Blender BL660 Power Button Panel Replacement: 步骤 3 中的图像 1,2 Ninja Professional Blender BL660 Power Button Panel Replacement: 步骤 3 中的图像 2,2
      • Using the Phillips #1 screwdriver, remove the 6 screws (13 mm long, 6 mm wide).
      询问修复机器人
      添加评论
    4. Ninja Professional Blender BL660 Power Button Panel Replacement: 步骤 4 中的图像 1,2 Ninja Professional Blender BL660 Power Button Panel Replacement: 步骤 4 中的图像 2,2
      • Using the Phillips #1 screwdriver, remove the two screws (5 mm long, 3 mm wide) holding the power cord onto the motor cover.
      询问修复机器人
      添加评论
    5. Ninja Professional Blender BL660 Power Button Panel Replacement: 步骤 5 中的图像 1,2 Ninja Professional Blender BL660 Power Button Panel Replacement: 步骤 5 中的图像 2,2
      • Using the iFixit plastic opening tool, pry the motor cover off the general housing. Once it is loose, lift it up to remove it off the base.
      • Slide the cover all the way to the end of the power cord.
      • Please note that the power cord does not completely come off the cover.
      询问修复机器人
      添加评论
    1. Ninja Professional Blender BL660 Power Button Panel Replacement, Power Button Panel: 步骤 6 中的图像 1,3 Ninja Professional Blender BL660 Power Button Panel Replacement, Power Button Panel: 步骤 6 中的图像 2,3 Ninja Professional Blender BL660 Power Button Panel Replacement, Power Button Panel: 步骤 6 中的图像 3,3
      • Using the Phillips #2 screwdriver, remove the four screws holding the circuit board to the housing.
      询问修复机器人
      添加评论
    2. Ninja Professional Blender BL660 Power Button Panel Replacement: 步骤 7 中的图像 1,1
      • Using a pair of scissors, cut the zip ties holding the power wires in order to give the circuit board mobility.
      询问修复机器人
      添加评论
    3. Ninja Professional Blender BL660 Power Button Panel Replacement: 步骤 8 中的图像 1,1
      • Using a Phillips #2 screwdriver, remove the 5 screws holding the power button panel cover.
      询问修复机器人
      添加评论
    4. Ninja Professional Blender BL660 Power Button Panel Replacement: 步骤 9 中的图像 1,3 Ninja Professional Blender BL660 Power Button Panel Replacement: 步骤 9 中的图像 2,3 Ninja Professional Blender BL660 Power Button Panel Replacement: 步骤 9 中的图像 3,3
      • Pull the power button panel cover off.
      • The power button panel comes off as a whole unit. Replace as needed.
      • Ninja Kitchen does not sell the power button panel. You will have to purchase one from a third party vendor.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 41
总计 2,031
